noob question. cel
Old Jan 10, 2005 | 04:59 PM
FadedEpic's Avatar
Default noob question. cel
Ok so I just want to run a test on my CEL but I have no idea where the plug in for the computer is at!! I looked forever while I was down at checker. I just thought it would be under the steering column...
When the guy who came out to look at it cuz i told him i am a noob and cant find it looked... he pointed to something and said 'oh thats it right there, its a honda specific one, we dont ahve a plug for that... but um that doesnt' sound right.
Anyone tell me?
Old Jan 10, 2005 | 05:35 PM
specialedition's Avatar
Default Re: noob question. cel (FadedEpic)
It is a blue connector located behind the center console.
4th gens it is behind the center radio console on the drivers side
5th gen is on the passenger side
take a paperclip and cut it in half then take the "U" clip that you just made and trip the blue connector now turn the car on (acc 11 pos).. If the check engine light comes on and does not blink then it is ok if it comes on and blinks then it has a code. A long blink is 10s and a short blink is 1s... hope it helps
Old Jan 10, 2005 | 10:32 PM
PrettyLude's Avatar
right underneath the radio, there is a panel on the right side of the console, pop the panel there it is, a blue 2 wire connector
Old Jan 10, 2005 | 11:04 PM
revlimitx04's Avatar
Default Re: (PrettyLude)
Middle consol, front passanger floor board to the very left, right under the radio. carpet panel pops off... blue 2 wire connector.
Old Jan 20, 2005 | 04:54 PM
ttboy's Avatar
What does long blink is 10s and short blink is 1s mean? So if I get 2 long blinks and 3 short blinks does that mean the CEL code is 23?
Where can I find a list of what these codes mean?
Thanks
Old Jan 20, 2005 | 05:16 PM
tonezilla's Avatar
Default Re: (ttboy)
yes that is correct .
btw, code 23 is the knock sensor
you can find a list of codes at:
http://tech.hybridgarage.com/tech/codes.html or
http://www.151boost.com/tech2.htm
Old Jan 20, 2005 | 05:17 PM
andeh22's Avatar
Default Re: (ttboy)
yep. 23.
at least im pretty sure.
search. theres some posts on here that tell you what the codes mean.
good luck
Old Jan 21, 2005 | 04:26 AM
PrettyLude's Avatar
http://www.hondata.com has all the codes listed
Old Feb 2, 2005 | 03:06 PM
FadedEpic's Avatar
what if the engine has two codes? I went to a shop and it claimed to have two codes. I didn't want them to do that, I took it in for a speedometer test and they jsut said "oh yay this car has a cel, lets pull some codes, then tried to charge me for it" even though i said i didn't want them to.
ANYWAYS, they said there were two, how would i find what the two are by this method? would it do some long ones, short ones, and immedietly follow it with another one thats long, short?
Old Feb 2, 2005 | 06:38 PM
PrettyLude's Avatar
it would blink two separate codes
Old Feb 2, 2005 | 07:26 PM
FadedEpic's Avatar
yep and how am I going to see them?
Autozone read it as one, and the shop showed two, is it possible that the reader my shop wasn't as nice or thourough?
Old Feb 2, 2005 | 09:36 PM
PrettyLude's Avatar
depends on which scanner you have at the shop, the ones from autozone aren't that accurate, but they will get you in the right ballpark
fe519
Feb 2, 2004 07:57 AM
tea
Jan 14, 2004 11:12 AM
tea
Jan 14, 2004 12:38 AM
littledan
Jun 19, 2003 11:56 PM
laurat
Oct 17, 2002 09:00 AM
