Radiator Cracked WHATS THE CAUSE/FIX. ?
Old Jan 10, 2005 | 02:06 PM
bla1ne's Avatar
Default Radiator Cracked WHATS THE CAUSE/FIX. ?
My radiator cracked few days ago on the top left about 5 - 6 inches long. Is it possible to do a quick fix tell I get a new one ? Or is it perty much shot ? And also what causes this to happen ? I was thinkin the thermostat because my heater doesnt work ether. I dunno. What do you guys think.
Old Jan 10, 2005 | 02:10 PM
GoFastMotorSports's Avatar
Default Re: Radiator Cracked WHATS THE CAUSE/FIX. ? (bla1ne)
A quick but not permanent fix is mans best friend JB WELD.
Old Jan 10, 2005 | 02:12 PM
bla1ne's Avatar
Default Re: Radiator Cracked WHATS THE CAUSE/FIX. ? (GoFastMotorSports)
What would cause a radiator to crack like this ?
Old Jan 10, 2005 | 02:15 PM
Rostr02's Avatar
a really sudden pressure increase would be my guess
Old Jan 10, 2005 | 02:20 PM
fourthgenhatchB17's Avatar
Default Re: Radiator Cracked WHATS THE CAUSE/FIX. ? (Rostr02)
Does the radiator have plastic end tanks?
Old Jan 10, 2005 | 02:22 PM
bla1ne's Avatar
Default Re: Radiator Cracked WHATS THE CAUSE/FIX. ? (fourthgenhatchB17)
what are those
Old Jan 10, 2005 | 02:24 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
"what are those?"
see: http://walnutcreekhonda.com/Repair/Radiator.jpg for example..
The cause would be ~Heat and pressure~..
Plastic is not the strongest material known to man..
It could be just caused by old age
or you may have an over-heating issue.
I would not drive it until the radiator
has been repaired or replaced and holds pressure.
Otherwise you risk overheating and warping the head.
I would probably replace the thermostat and the radiator cap
and flush the cooling system while you are at it.
Modified by 88DXCRX at 7:09 PM 1/10/2005
Old Jan 10, 2005 | 02:29 PM
HipHop Head's Avatar
Default Re: Radiator Cracked WHATS THE CAUSE/FIX. ? (88DXCRX)
i would buy a new radiator to start fresh .. i think for it to crack would be a high pressure increase and also your radiator could be old is it the stock one the car came with . if it is then that's alot of yrs u have a 88 crx ?
Old Jan 10, 2005 | 02:34 PM
bla1ne's Avatar
Default Re: Radiator Cracked WHATS THE CAUSE/FIX. ? (Ej Oner)
No its a 1990 si with the fi d15b. The motor swap was done by the old owner.
Old Jan 10, 2005 | 02:38 PM
oh i see the sohc vtec? did u try buying a new radiator
Old Jan 10, 2005 | 03:03 PM
bla1ne's Avatar
non vtec port and polished head.
Old Jan 10, 2005 | 03:22 PM
prettysweetcivic's Avatar
JB Waterweld works wonders, it held together my chevy's radiator for years, and its still there
Old Jan 10, 2005 | 03:37 PM
PHOBIA's Avatar
if it's on the plastic neck then i too would use jb weld"i have done this but with bad results" and then slide the hose as far as possible over it,when you use the jb weld.as soon as you apply it take a heat guin to it to get it super hard then wait over night and you should be ok for a little bit.
tolnep's Avatar
I have a 91 CRX. I was working on it about a month ago, leaned it the top and I think I cracked the top (plastic). About 4 to 8 inches I guess. So I get on the internet and find that I can buy a new one for 80 or 90 bucks and thats what I did. Replace the old plastic thing with a new one. Is easy and good for piece of mine.
The top and bottom of the old ones are plastic and eventually crack for everyone.
Old Jan 10, 2005 | 11:53 PM
2:1's Avatar
2:1
5-6 inches is a damn big crack, needs to be replaced soon,
Skeetzy
19
Nov 14, 2016 08:51 AM
inaety
Aug 4, 2011 04:15 PM
maddcrx
Honda S2000
Jun 7, 2008 10:03 PM
Jack Black
Feb 23, 2004 07:50 PM
EGh22aEG
Jan 9, 2002 06:37 PM
