water/coolant for T25/T28 turbo....
Old Jan 10, 2005 | 11:46 AM
ncervantes's Avatar
Default water/coolant for T25/T28 turbo....
I wanted to know if it is required to run the coolant through T25/T28 turbo? Someone told me that I didn't have to, that I could just plug the holes. Is this correct? Will this effect my turbo?
Old Jan 10, 2005 | 12:05 PM
93turbo16's Avatar
You don't have to but it is there for a reason. I always say to run them. There is really no reason, except for laziness, not to.
Old Jan 10, 2005 | 12:29 PM
beepy's Avatar
Default Re: water/coolant for T25/T28 turbo.... (ncervantes)
It takes 10 minutes to plumb the water lines, and that will save you from having to do a 60-second cooldown after every time you drive your car. It's up to you.
(Note that the cooldown is only not required when you finish your drive under low load, which is usual)
Modified by beepy at 11:48 PM 1/10/2005
Old Jan 10, 2005 | 12:40 PM
ncervantes's Avatar
Default Re: water/coolant for T25/T28 turbo.... (beepy)
So basicaly If I set my turbo timer to 60sec I will be fine? That seems allot easier especially if there are no consequences...lol
Old Jan 10, 2005 | 12:41 PM
93turbo16's Avatar
True, but why not just hook them up?
Old Jan 10, 2005 | 12:48 PM
ncervantes's Avatar
Default Re: (93turbo16)
Some people say that there is a possibility of over heating with the lines. On a stock 1.6, I don't wanna take that chance. Suggestions?
Old Jan 10, 2005 | 12:56 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (ncervantes)
who are these some people?
id use them.....
Old Jan 10, 2005 | 01:00 PM
Marauder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ncervantes &raquo;</TD></TR><TR><TD CLASS="quote">So basicaly If I set my turbo timer to 60sec I will be fine? That seems allot easier especially if there are no consequences...lol
I'm sure you'd get more life out of it with the water hooked up.
Old Jan 10, 2005 | 01:01 PM
ncervantes's Avatar
Default Re: (Hella_JDM)
Are you saying that is not likely? I guess it's not a big deal to add them, was just told it's basically a waste. *shrug*
Old Jan 10, 2005 | 01:51 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">who are these some people?
id use them.....</TD></TR></TABLE>
These "some People" don't sem to be well informed.....
Old Jan 10, 2005 | 02:01 PM
Bailhatch's Avatar
Default Re: (TheShodan)
I have never hooked them up and never had a problem. I have done about 10 junkyard turbos w/o water (and more new turbos). All going strong, some for years now.
I have never heard of overheating from using them. I really doubt that its true. I have heard of having a messy looking engine bay and extra places for leaks but that could be a rumor too
Old Jan 10, 2005 | 02:47 PM
93turbo16's Avatar
I run water lines on all my turbos if they come with it. It is just dumb not too, I am not saying that it helps or hurts anything by running and not running them. I just think if it is built for water, hook them up.
95BoostedEJ1
Feb 22, 2009 08:15 AM
purple98ek
Aug 13, 2007 10:50 PM
1QwIkEf
Jan 29, 2006 07:47 PM
street dreams
Oct 9, 2004 05:55 PM
dave'sh22a4
Jan 22, 2003 06:42 AM
