how to pin vtec and distributor for h22 swap???
Old Jan 10, 2005 | 11:39 AM
azzinine1's Avatar
Default how to pin vtec and distributor for h22 swap???
i tried searching but i couldnt find anything i was just wondering if anyone could tell me or give me a diagram for how to pin the vtec and distributor into the ECU for the h22 swap, its a 93 h22a in a 96 lx accord...thanks
Old Jan 11, 2005 | 05:16 AM
azzinine1's Avatar
Default Re: how to pin vtec and distributor for h22 swap??? (azzinine1)
bump
Old Jan 11, 2005 | 08:44 AM
Carolina Fried Rice's Avatar
bump because azzinine has been F***ed by the shop that his car is STILL sitting at... someone knows this out there.
Old Jan 11, 2005 | 09:40 AM
Stew Pidasso's Avatar
Hope this helps ... http://www.accordinglydone.com...p?a=2
Old Jan 11, 2005 | 05:41 PM
azzinine1's Avatar
Default Re: how to pin vtec and distributor for h22 swap??? (Stew Pidasso)
Thanks for the info I really appreciate it...now I have a new problem. I have wiring info from someone else that tells me to wire the vtec solenoid, vtec pressure switch, IAB, and knock sensors to the accords bulk head (the actual clips that connect to the ecu incase I have the name for that wrong). its says to wire to these pins.
VTEC solenoid to pin A8
VTEC pressure switch to pin C15
IAB pin A26
Knock sensor pin D6
the link above says to wire it to the ECU at these locations...
VTEC Solenoid: Grn/Yel on Prelude harness > Pin A4 on ECU // SENSOR LOCATION: Near distributor
VTEC Pressure Switch: Lt Blu on Prelude harness > Pin D6 on ECU // SENSOR LOCATION: Near distributor
Blk/Red > Ground
IAB: Pink on Prelude harness > Pin A17 on ECU // SENSOR LOCATION: Drivers side of intake manifold
Blk/Yel > 12V
Knock Sensor: Red/Blu on Prelude harness > Pin D3 on ECU // SENSOR LOCATION: Middle back of block
I have a OBDII to OBDI conversion harness from boomslang.com. Is it possible that because of the conversion harness I should pin to the accord harness or should I still pin to the ECU. Also I have the pin order for the accord harness from AllData.com and I have heard that they somtimes have the pins in the wrong order, can anyone give me a diagram on the correct pin order for a 96 accord lx coupe.
Sorry for the long post, I havent had a car for six months now...long story but someone screwed me over and im trying to figure this out myself now so any help would be greatly appreciated. THANKS
Old Jan 11, 2005 | 07:08 PM
a4thgenaccord's Avatar
Try this
http://www.geocities.com/honda....html
Old Jan 11, 2005 | 07:58 PM
azzinine1's Avatar
Default Re: how to pin vtec and distributor for h22 swap??? (a4thgenaccord)
that kinda helps but also has different pin locations now i have 3 different pin outs...anyone else???
hondamyheart
15
Aug 5, 2018 11:24 PM
mills7x
Apr 2, 2012 11:29 AM
sameerb1
Feb 22, 2011 08:33 PM
KY
Dec 22, 2004 05:46 PM
SuperNemeSis
Mar 29, 2003 02:32 PM
