Can i use my new clutch in my 93 dx when doing a si motor and trany swap?
Old Jan 10, 2005 | 09:18 AM
ted's Avatar
ted
Default Can i use my new clutch in my 93 dx when doing a si motor and trany swap?
Hey i have a 93 civic hatch dx with a stage 1 clutch. i plan to do a si motor and trany swap for my car. Can i use the clutch from my dx and use it on the si motor and trany swap. are the clutchs the same or are they diffent? thank u vary much..
Old Jan 10, 2005 | 09:20 AM
Lee_Delso's Avatar
Default Re: Can i use my new clutch in my 93 dx when doing a si motor and trany swap? (ted)
Are you talking about a d16 or a b16? If it's a d16 then yes they are compadible from what I know. I just looked in the ACT catalog and they're all the same part number for a sohc.
Old Jan 10, 2005 | 09:28 AM
ted's Avatar
ted
O soory i plan to do a D16 swap..
Old Jan 10, 2005 | 09:46 AM
snatch's Avatar
Default Re: (ted)
If you do a D16 SOHC VTEC swap (ie: D16Z6 or D16Y8), then yes you can use the same clutch. In fact, all D-series clutches are interchangeable.
Old Jan 10, 2005 | 12:08 PM
ted's Avatar
ted
ALLRIGHT THANKS ALOT
Old Jan 10, 2005 | 12:49 PM
2camvtec's Avatar
Default Re: (ted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ted &raquo;</TD></TR><TR><TD CLASS="quote">O soory i plan to do a D16 swap..</TD></TR></TABLE>
You are confusing the sh*t out of me .<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ted &raquo;</TD></TR><TR><TD CLASS="quote">Hey i have a 93 civic hatch dx with a stage 1 clutch. i plan to do a si motor and trany swap for my car. Can i use the clutch from my dx and use it on the si motor and trany swap. are the clutchs the same or are they diffent? thank u vary much..</TD></TR></TABLE>
Old Jan 10, 2005 | 12:51 PM
2camvtec's Avatar
Default Re: (2camvtec)
opps my bad I just realized you weren't talking abou tthe 99-00 Si's
Old Jan 10, 2005 | 01:56 PM
civicminded92's Avatar
Default Re: (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">If you do a D16 SOHC VTEC swap (ie: D16Z6 or D16Y8), then yes you can use the same clutch. In fact, all D-series clutches are interchangeable.</TD></TR></TABLE>
Not ALL are interchangeable -
pre and including 88 clutch diameter = 190mm
89 clutch diameter = 200mm
92-03 D series clutch diameter = 212mm
So to say 5th gen and up, all D series clutches are interchangeable. Sorry to be retentive.
Old Jan 11, 2005 | 05:24 AM
snatch's Avatar
Default Re: (civicminded92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicminded92 &raquo;</TD></TR><TR><TD CLASS="quote">
So to say 5th gen and up, all D series clutches are interchangeable. Sorry to be retentive. </TD></TR></TABLE>
I stand corrected. Thank you sir.
Bond
24
Apr 1, 2005 12:08 PM
scorched0
Jul 11, 2004 10:10 PM
new_to_hondas
May 18, 2003 05:41 PM
.Beaver
Jun 30, 2002 01:20 AM
