Are B16 blocks interchangeable?
Old Jan 10, 2005 | 08:36 AM
ICeDoUt's Avatar
Default Are B16 blocks interchangeable?
https://honda-tech.com/zerothread?id=1109564
Hybrid forum moves sooo slow, and doesn't seem to get as many views as tech.
Old Jan 10, 2005 | 08:58 AM
b18bturbo's Avatar
Default Re: Are B16 blocks interchangeable? (ICeDoUt)
yes the b16a1,2,3 are all interchangeable buth e 3 model is obd II block from the si series which means you have provisiono nthe oil pump for the crank sensor. but other wise you can switch the bseres oil pump with a obd 1 pump and you will have block that is obd1 as well but yes all of the blocks are interchangeable
Old Jan 10, 2005 | 09:04 AM
ICeDoUt's Avatar
Default Re: Are B16 blocks interchangeable? (b18bturbo)
alright cool, and would the obd0 oil pump also fit on the b16a3 block?
Old Jan 10, 2005 | 09:49 AM
b18bturbo's Avatar
yes but i wouldnt reccomend using a used oil pump on any type of build
Old Jan 10, 2005 | 09:50 AM
PrettyLude's Avatar
like viren said it will work the only difference is that the obd2 oil pump has the crank sensor on it
mot3020
Apr 5, 2013 07:38 PM
nighttrain33
Oct 3, 2006 07:30 PM
coconutsoldier
Jun 18, 2005 05:37 PM
warwagon
Jan 11, 2005 05:14 PM
Turbo Lude SH
Nov 4, 2002 11:30 AM
