Two questions
After searching, I didn't find the good help I need.
I want to change my steering wheel, and I onlys found instructions for the newer model with airbags and ****.
I'm also ready to modify my front bumper, but I can't get it off. I found a How to on http://members.aol.com/td04civic/how_to.htm#grill but it wasn't too detailed though. Those screws on each side isn't screws, but bolts, and I can't get them off.
So a good how to/walkthrough on those two questions for my civic hb '94 would be great! Thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Klokka »</TD></TR><TR><TD CLASS="quote">I want to change my steering wheel, and I onlys found instructions for the newer model with airbags and ****.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Klokka »</TD></TR><TR><TD CLASS="quote">for my civic hb '94</TD></TR></TABLE>
well lets see, if you have a 94 Civic hatch then you have a steering wheel with airbag. so what other instructions would you need?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Klokka »</TD></TR><TR><TD CLASS="quote">I'm also ready to modify my front bumper, but I can't get it off. I found a How to on http://members.aol.com/td04civic/how_to.htm#grill but it wasn't too detailed though. Those screws on each side isn't screws, but bolts, and I can't get them off..</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Klokka »</TD></TR><TR><TD CLASS="quote">So a good how to/walkthrough on those two questions for my civic hb '94 would be great! Thanx</TD></TR></TABLE>
if you need a "how to" on taking your bumper off, i dont think it would be a good idea to try to do anything yourself to your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FdOoUoRr »</TD></TR><TR><TD CLASS="quote">well lets see, if you have a 94 Civic hatch then you have a steering wheel with airbag. so what other instructions would you need?
well if he doesn't live in the states, his car very well may not have a driver's airbag. nevertheless, removal should be even EASIER than WITH an airbag. just unscrew the horn pad from behind, then use a 19mm socket to undo the nut that holds the steering wheel to the column
Nextelbuddy
May 20, 2005 07:21 PM
SIR Spooner
Mar 8, 2004 07:50 PM
