Oil pouring out on Swap, help?
Old Jan 9, 2005 | 11:49 PM
sporty240's Avatar
Default Oil pouring out on Swap, help?
So I swap in a gsr into my hatch tried to start it up, it cranks up start ran it for like 20 sec and I was happy, left it alone. The next day I was under the car to hook up the exhaust cuz I ran it with just the header and I notice a somewhat meduim puddle of oil under the car. I tried to start it up again ran it for like 20-30 sec and turned it off went to check and there oil pouring from underneath the car I was pissed. took a look to see if it was comming from filter/oil cooler area and it wasnt, it also not from the pressure sensor.. I thought it was the PCV valve leaking but its not there was oil on top of it coming from the thermostat area of the block... it looked like 1/2-1 quart of the oil came out on the ground...
do u guys think its the headgasket?
the motor was not run since it was rebuilt I'm not sure if they reused the hg
Old Jan 9, 2005 | 11:53 PM
SirRevvs's Avatar
Default Re: Oil pouring out on Swap, help? (sporty240)
Are you leaking any oil from around the distributor?
Old Jan 9, 2005 | 11:55 PM
civicdust's Avatar
Default Re: Oil pouring out on Swap, help? (SirRevvs)
make sure the vtec pump is tightened. I had the same prob
Old Jan 9, 2005 | 11:56 PM
sporty240's Avatar
It doesnt look like it can leak that much oil in that short amount of time cuz it only leaks when the car is running theres like oil along the whole side of that corner where the thermostat is at..
Old Jan 9, 2005 | 11:59 PM
sporty240's Avatar
Default Re: Oil pouring out on Swap, help? (JoseDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoseDM &raquo;</TD></TR><TR><TD CLASS="quote">make sure the vtec pump is tightened. I had the same prob </TD></TR></TABLE>
what vtec pump? u mean the solenoid? most of the oil is comming from the back side of the block but the same side as solenoid, the solenoid is towards the front...
Old Jan 10, 2005 | 12:05 AM
civicdust's Avatar
check eitther way. Make sure your dizzy is all the way in.
Also, do you notice it leaking from the valve cover?
because i think if it was the headgasket you would be smoking. (someone correct me)
Old Jan 10, 2005 | 12:13 AM
sporty240's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoseDM &raquo;</TD></TR><TR><TD CLASS="quote">check eitther way. . (someone correct me)</TD></TR></TABLE>
it doesnt look like the valve cover but I will check the distributor tommorow, thanks
there doesnt seem to be any coolant comming out, it doesnt seem to be smoking but I only tried to run it a couple of times for about 10-20 sec after I added more oil...
Modified by sporty240 at 9:24 AM 1/10/2005
Old Jan 10, 2005 | 01:14 AM
edo3276's Avatar
check oil pan area and the area between the block and the tranny....could be rear main seal or oil pan gasket or front main seal.
Old Jan 10, 2005 | 01:16 AM
showtymers619's Avatar
* B A N N E D *
Default Re: Oil pouring out on Swap, help? (edo3276)
check your oil filter.. you might have a double gasket occuring
Old Jan 10, 2005 | 01:41 AM
Timmay's Avatar
Default Re: Oil pouring out on Swap, help? (ShowTymers619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShowTymers619 &raquo;</TD></TR><TR><TD CLASS="quote">check your oil filter.. you might have a double gasket occuring</TD></TR></TABLE>
beat me to it
Old Jan 10, 2005 | 09:03 PM
sporty240's Avatar
Default Re: Oil pouring out on Swap, help? (Timmay)
checked it its dry around the distributor and oil filter looks like its coming out from between the block and the head, I checked how much oil was in there, it looks like more than 1 quart came out...
I dont get it the motor was just rebuilt just started up and started spewing oil out
anybody?
Old Jan 10, 2005 | 10:14 PM
31flavorscivic's Avatar
because i think if it was the headgasket you would be smoking. (someone correct me)</TD></TR></TABLE>
I shall. I beat the **** out of a sunfire and blew headgasket in 4 places. It just leaked outwardly, and not into any of the cylinders. Wouldn't cause anything as bad as what he is describing though.
edit: I think...
Old Jan 11, 2005 | 12:27 AM
sporty240's Avatar
Default Re: Oil pouring out on Swap, help? (31flavorscivic)
I guess ill have to start it up and get under the car seed wherre its coming from, I havent really run alot maybe 10-15 sec at a time dont want to damage the engine...
Old Jan 11, 2005 | 05:29 PM
sporty240's Avatar
if the GSR head that is on my block right now was used in a LSVtec setup and the oil hole that is usually blocked for lsvtec is left plugged, and then put on my gsr block could the oil pressure cause my head gasket to leak like that???
that is what I am thinking cuz that oil hole is right it the same corner that is covered in oil....
Old Jan 11, 2005 | 06:17 PM
sykotik sol's Avatar
did you install the head gasket? if so you may have it on upside down! i know this from experience..lol
Old Jan 11, 2005 | 06:18 PM
B2FiNiTY's Avatar
Clean the area and look at it while the car is running. Could be anything!
Old Jan 11, 2005 | 06:22 PM
Default Re: Oil pouring out on Swap, help? (B2FiNiTY)
yea, thats what i did..spray some "enginekleen" on the areas where u think it might be coming from , let it evaporate, start car again and peep where she's squirt'n from..lol
Old Jan 11, 2005 | 07:12 PM
BrOkE_ass_sKaNk's Avatar
check you oil plug that you tapped did you just put it in with no seal(silicon) or anything check that spot it might leaking from there
Old Jan 11, 2005 | 08:52 PM
RTE117's Avatar
Cam seals good and in place? If they're outta place they'll make a weird cackling noise. Here's 10 or so min worth of driving with a bad cam seal (these are POST clean up ):
Old Jan 11, 2005 | 08:56 PM
eK9aT10pSi's Avatar
oil pressure switch loose ?
PatrickFrantz
Jan 11, 2009 08:51 AM
tico
Jun 21, 2008 01:20 PM
HondaEJ7
Feb 13, 2006 05:18 PM
k20dc2
Aug 7, 2005 05:30 AM
WannaHonda
Aug 31, 2004 10:47 PM
