manley turbo tuff rods hp rating????
Old Jan 9, 2005 | 02:32 PM
W C L's Avatar
Default manley turbo tuff rods hp rating????
i havea set of manley trubo tuff rods that i picked up for dirt cheap new in box, and was wondering the hp rating on them...
Old Jan 9, 2005 | 03:17 PM
b16sedan's Avatar
Default Re: manley turbo tuff rods hp rating???? (W C L)
More than you're going to make.
Old Jan 9, 2005 | 03:43 PM
earl's Avatar
Default Re: manley turbo tuff rods hp rating???? (b16coupe)
rods don't have horsepower ratings...they break because of rpms...horsepower ratings are just a figment of some marketing guy's imagination.
Old Jan 9, 2005 | 03:58 PM
NJIN BUILDR's Avatar
Default Re: manley turbo tuff rods hp rating???? (earl)
So true.They use to rate rods in #'s of tinsel failure.The test fixture held the rod thru the pin end and crank end.Then the rod was pulled apart at a set rate.The #'s it took to destroy the part was its rating.That must have been a fun job.
Glenn
Old Jan 9, 2005 | 04:01 PM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">rods don't have horsepower ratings...they break because of rpms...horsepower ratings are just a figment of some marketing guy's imagination.</TD></TR></TABLE>
What about torque? Diesels have some big beefy rods, but they're usually turning half or a third the RPM's a little honda turns.
Old Jan 9, 2005 | 05:19 PM
W C L's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe &raquo;</TD></TR><TR><TD CLASS="quote">More than you're going to make.</TD></TR></TABLE>
power is not an issue.....with my 76mm friend
Old Jan 9, 2005 | 09:21 PM
earl's Avatar
What about torque? Diesels have some big beefy rods, but they're usually turning half or a third the RPM's a little honda turns.</TD></TR></TABLE> I am not a scientist but there is an equation something like
force=mass X Velocity Squared
force is what breaks the rod.
mass is the weight of the piston and rod
and velocity is a factor of engine rpms and rod/stroke ratio
since it is mass X velocity X velocity....rpm factors big into rod breakage
Since a diesel runs on detonation, I think the rods must be able to take the abuse for another reason.
I'm in over my head on this explanation but I hope there are some college physics majors who can expand on this
Old Jan 15, 2005 | 11:00 AM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote"> I am not a scientist but there is an equation something like
I'm in over my head on this explanation but I hope there are some college physics majors who can expand on this</TD></TR></TABLE>
i belive force = mass X acceleration, so the faster a motor is turning the faster it is accelrating, velocity squared would be gxm^2/s^2 and force is in the units of g x m / s^2
Old Jan 15, 2005 | 07:52 PM
earl's Avatar
Default Re: manley turbo tuff rods hp rating???? (Boosted Chemist)
yeah acceleration and I guess deceleration is a better way to put it than velocity. The higher the rpms, the quicker the rod has to accelerate and then decelerate in any given cycle.
Old Jan 17, 2005 | 12:09 PM
Full-Race Geoff's Avatar
exactly, its acceleration that breaks ****, not constant velocity.
yaaj1320
Apr 24, 2007 08:49 PM
h22silvia
Feb 1, 2007 04:49 PM
litovi3tboi503
Jan 15, 2007 09:00 PM
litovi3tboi503
Jan 14, 2007 07:02 PM
Gatweb
Feb 6, 2006 07:11 PM
