Starting problem.....
Old Jan 9, 2005 | 11:24 AM
85DX's Avatar
Default Starting problem.....
For the past little while when I went to start my car it would just click but after a couple trys it would start. Today when I went to start it I got nothing not even a click. Anybody have any suggestions on what has happened? Time for a new starter?
Old Jan 9, 2005 | 11:55 AM
Chiovnidca's Avatar
Default Re: Starting problem..... (85DX)
I'd check the condition of the battery,cables and connections first. Sounds like bad starter contacts though.
Old Jan 9, 2005 | 12:00 PM
dynamitezz's Avatar
Ok you can do a lot to see what is going on. First I would check spark, the conditions of your battery cables and the condition of your battery. Try those and diagnose your problem.
Old Jan 9, 2005 | 12:46 PM
RCautoworks's Avatar
Default Re: Starting problem..... (dynamitezz)
Check the battery voltage and see what your getting, clean all connections and if it still don't work. Take something heavy and have some turn the key, and hit the starter. Usually the solenoid sticks and this will unstick it, but in the long run you will need a new starter.
airsodam
Jan 30, 2006 10:55 PM
whatcivic
Dec 6, 2005 05:20 PM
krnfly2damoon
Sep 5, 2005 08:49 AM
FalconMan
Aug 19, 2005 06:02 PM
john457
Aug 16, 2005 10:20 PM
