slight hole on brake booster, right below MC
Old Jan 9, 2005 | 10:48 AM
mingbling96's Avatar
Default slight hole on brake booster, right below MC
so yea.. there's a tiny small hole rite there.. I have no idea where it came from. anybody have n e idea how that came about? and is my brake booster bad?
Old Jan 9, 2005 | 11:19 AM
Luserkid's Avatar
Default Re: slight hole on brake booster, right below MC (mingbling96)
Did you try to hammer a nail in it and thought it might be a wrong idea so you pulled it out? Is it, was it leaking?
Old Jan 9, 2005 | 11:22 AM
alotawatts's Avatar
JB Weld it ?
Old Jan 9, 2005 | 11:33 AM
Default Re: slight hole on brake booster, right below MC (Luserkid)
i'm going to have to look closer at it. It's not leaking or anything.. i think it mite just be paint coming off..
Old Jan 9, 2005 | 11:41 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling96 &raquo;</TD></TR><TR><TD CLASS="quote">i'm going to have to look closer at it. It's not leaking or anything.. </TD></TR></TABLE>
If it's not leaking it's probably not a hole.
Old Jan 9, 2005 | 12:55 PM
jlacoy82's Avatar
71.192.16.183
Default Re: slight hole on brake booster, right below MC (Chiovnidca)
If it IS leaking, replace it. Brake fluid sprayed all over your engine bay wont do you any favors.
Old Jan 9, 2005 | 03:00 PM
how can brake fluid be leaking from the brake booster? fluid doesnt go through the booster... only through the MC
Old Jan 9, 2005 | 03:06 PM
jlacoy82's Avatar
71.192.16.183
Im retarded.
Old Jan 9, 2005 | 03:21 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mingbling96 &raquo;</TD></TR><TR><TD CLASS="quote">how can brake fluid be leaking from the brake booster? fluid doesnt go through the booster... only through the MC</TD></TR></TABLE>
I never said anything about leaking brake fluid, this other guy did.
Old Jan 9, 2005 | 04:10 PM
okae.. figured it out. Its not a hole, but a lil slight indentation rite below the MC. All brake boosters have it.. and i think it's designed to be like that so that when your MC goes bad and leaks, that the fluid will be able to leak out the bottom of the MC.
Andyxramirez
Mar 11, 2013 05:56 PM
DjSniperwolf
Aug 25, 2010 04:53 PM
Chef Andre
Suspension & Brakes
Jul 22, 2010 08:22 PM
spintboy
17
Jan 3, 2008 08:49 AM
