Used piston rings??? SHould I USe them ?
Why gamble having to tear apart the motor over $80?
bearings, rings should always be replaced when rebuilding/tearing down a motor
Just work 1 overtime shift or ask mommy to cover the cost so you dont have to mess the driveway
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by velocitytrends »</TD></TR><TR><TD CLASS="quote">NO!</TD></TR></TABLE>
thasnk for th heads up.. i may just sell it all ( eagle rods wtith srp;s) ..... i found a used set od crower rods and maybe i;ll get soem cp pistons..... there goes a budget build
at least i will get reliablity and piece of mind
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKchump »</TD></TR><TR><TD CLASS="quote">i dont think i'd even use used pistons again. </TD></TR></TABLE>
umm you have never bought 400$ pistons then i guess.
your funny
your funny
reusing pistons and rods are no problem, as long as they are still in spec and have the proper clearances. I wouldn't jump to the conclusion of selling everything you got to get something different unless you absolutly want too. If you are trying to do a budget build up just stick with what you got and get some new bearings from Honda and some new rings from JE/SRP.
