Does the EGR Valve make it run worse
A guy I want to buy a car from took off the EGR valve becuase it was a little "doggier" with it on. Is it normal for a car to have a little less power with the EGR valve connected? Is there some way to know if the valve is good or bad?
This is a 91 CRX HF 180K
Thanks
Modified by niceguy12 at 3:47 PM 1/8/2005
Thanks
From: I told you to wait in the truck in Texas, United States
If the valve is malfunctioning and hanging open,
It is essentially like a large vacuum leak at idle and it will
run rough as though it has a dead miss..
If the valve is bad,The ecu will usually throw a code..
ECU=electronic control unit or "brain"
Is the check engine light on or does it even work?
It should come on/go off when you turn on the key..
EGR would be a code 12 in this case..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niceguy12 »</TD></TR><TR><TD CLASS="quote">What's an mi16?</TD></TR></TABLE>
Its the name of his car..
Peugeot 405 "mi16"
Peugeot 405 "mi16"
Yes the check engine light was on when I test drove the car and the present owner told me why it was on (egr) I didn't see it flashing or anything like that but I was only in the car for 15 minutes
