Need help on the ITR manifold in a B16?????
Old Jan 8, 2005 | 01:51 PM
92_EGhatch's Avatar
Default Need help on the ITR manifold in a B16?????
Well i have just put the itr mainfold in my B16, and just now started the ignition or started the engine. and have a problem. My engine sounds like it's leak, and rpm is at 2000 when i start the engine.
*<U>What i used</U> is the stock intake manifold gasket, the b16 throttle, and the B16 fuel line.
*<U>WHat happen?</U> it leaks from the throttle body, and RPM is @ 2000
Old Jan 9, 2005 | 06:57 PM
eg_type_r93's Avatar
Default Re: Need help on the ITR manifold in a B16????? (92_EGhatch)
get a new throttle body gasket and adjust the idle (little screw by throttle body cable connector)
Old Jan 11, 2005 | 11:42 AM
92_EGhatch's Avatar
Default Re: Need help on the ITR manifold in a B16????? (eg_type_r93)
Well i felt that it leaks and the engine keeps on reving highso thats why i went to get a new intake manifold Gasket & throttle gasket and put my stock back on. So i Return the Type_r manifold back.
Old Jan 11, 2005 | 04:16 PM
smart monkey's Avatar
did you use the R t body gasket or B16a one? you are suppose to use the B16a gasket.
Old Jan 12, 2005 | 09:02 PM
ELABR8's Avatar
Default Re: Need help on the ITR manifold in a B16????? (smart monkey)
make sure u put it in the right way too cause i remember putting it the wrong way and it leaked
Old Jan 13, 2005 | 10:21 AM
92_EGhatch's Avatar
Default Re: Need help on the ITR manifold in a B16????? (egs4life)
well i decided to not put it on no more, and plus i found out that the b16 P30 help out more then the itr. Why? because there's a book that shows the dyno on it.
crazyguy
Jan 12, 2008 05:05 AM
bootlegtrader
Feb 3, 2006 07:17 PM
dohcMONSTER
Apr 22, 2004 02:59 PM
Kevedge
Feb 21, 2004 08:12 AM
