Back up lights don't work
i noticed the other night that my back up lights don't work. I checked the bulbs because both don't work and they were fine. i checked the fuse under the dash and the fuse was not blown. any ideas?
Reverse light switch.
I have the same exact problem and i still haven't got around to fixing it.
The switch is located on the top of the tranny.
for more info about how to install
search archived: ''reverse light switch''
check the switch on the tranny.if it is working,there must be a break in the wiring-start checking for continuity along the different parts of the circuit until you find the break.
Chris
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicehatchy »</TD></TR><TR><TD CLASS="quote">how do i know that if the switch is working or not when i pull it out</TD></TR></TABLE>
it should have continuity when pressed,and not when let out.it may be the other way around,but you get the point-in one position it lets current pass,the other way it doesn't.if it doesn't let voltage through at all,that's your problem.
Chris
Chris
Silvertune
11
Apr 15, 2012 09:20 PM
mustninty
Aug 17, 2004 03:26 AM
