Spoon or Standard CTR/ ITR clusters ..........
well im not a genuis but im guessing if you want an integra R cluster youll need an integra dash
And thats another no for the CTR it only came in 96 and up----> right? so unless you swap dashes then your stuck. The ITR one seems more doable never seen an eg go to an ek.
[Modified by MrPimpon, 3:31 PM 1/9/2002]
And thats another no for the CTR it only came in 96 and up----> right? so unless you swap dashes then your stuck. The ITR one seems more doable never seen an eg go to an ek.[Modified by MrPimpon, 3:31 PM 1/9/2002]
I already have a ITR dash .
The reason I want to put it in is since I am going to be modifing my ECU shortly to aid engine performance , I will now be reving 9000-9200 rpm !
And since I am not really a fan of 5inch tachs and smaller tachs look even cheesier . I rather stick OEM and run a OEM cluster .
And lastly reason 2 :- the speedo in and EG doesn't go far enough !
I would swap in the complete GSR dash , but the cut door panels looks kinda sloopy .
my mommy said i was different cuz i wore two right shoes
"but mommy do all the little boys and girls have 2 right feet"
"no honey, but that is what makes you different and being different is good"
-=Z
b20bastard , can you send a pic of your door panels ?
Wiring is not a problem I have a friend with a degree in Electronic and electrical engineering . and I have not yet seen anything he can't wire up .
So with the help of a wiring diagram , it is no problem
THanks guys
THanks guys
my door panels look like ****, theyre nothign to brag about. i cut them muself with a shitty saw, i forgot to pull back extra vinyl to wrap around the edge. i think im jsut gonna yank them off and put up alluminum on both sides. good luck with the swap.i have another pic of the interior, ill try and post it later when i get home onto my own computer.
yeah JDM clusters can work but the speedo still doesn't go to far , and when the speed needle reaches its peak , the spring or what ever breaks . Therefore I have to spend more money every week to fix it .
we didnt repin, we usded but connectors,
wasnt thinking, it looks like a mess, pin connectors would have been a lot easier, im sure wiring diagrams would have helped as well.
yea mxpx rocks! i was wondering if someone was gonan comment on that.
Have any of you got any wiring diagrams on you computer that you can email to me at hybrid_neil@hotmail.com
Alaskan98ITR406
Sep 24, 2002 12:58 PM
