Should I rechip or will my motor run fine?
Old Jan 8, 2005 | 11:37 AM
Doug684's Avatar
Default Should I rechip or will my motor run fine?
Ok I have a 91 Civic SI with a Y8 swap going in. The Y8 has been built with JE 10.5:1 c/r pistons, eagle rods, port and polish Y8 head with over sized intake valves. It will also have ram intake and 2 1/2" catback exhaust with gutted cat.
Now here is the question. My PM6 ecu was chipped with a stock A6 map minus rev limiter. Will this still run my Y8 swap fine or should I have another chip burned?
Old Jan 8, 2005 | 12:10 PM
Doug684's Avatar
ttt
Old Jan 8, 2005 | 12:21 PM
Burlyirishdude's Avatar
Default Re: (Doug684)
did you go .5 over or 1 over on the Intake v.
I would say go with the y8 chip. Simply cause you prolly could run the a6 but the y8 will prolly do better with a little ecu tunning. It couldn't hurt. good luck. I love your setup so far.
Old Jan 8, 2005 | 12:22 PM
I8ayellowcrayon's Avatar
You won't have VTEC if you're using the PM6. I think it would be ok just so you ran some 91+ octane fuel. You surely wouldn't see the same affects as using a P28 that's tuned (chipped) for that motor.
Old Jan 8, 2005 | 12:51 PM
Doug684's Avatar
Default Re: (I8ayellowcrayon)
The vtec is going to be controlled by a MSD rpm activated switch.
Ekevans08
Dec 12, 2012 06:11 AM
myEK=slow
May 3, 2006 04:59 AM
gmcrxsi
Aug 13, 2005 12:27 PM
krazeemidget
Apr 17, 2003 07:23 AM
