Suspension & Brakes Theory, alignment, spring rates....
sway bar hardware source?
Old Jan 8, 2005 | 09:19 AM
lemansteve's Avatar
Default sway bar hardware source?
Hey all, i've got a suspension techniques rear sway bar for my 97 CL (same bar as on the 94-97 accord). Long story short, i am missing some hardware for it: the L-shaped endlink brackets, the two black metal adapter-type things and the two flat metal inserts that attach to the two large central bushings. Does anyone know where I can get these parts? maybe someone has them lying around somewhere...?
Old Jan 8, 2005 | 09:25 AM
gunnis's Avatar
Default Re: sway bar hardware source? (lemansteve)
i would make the assumption the suspenions techniques bar is larger in diamter than the 94-97 bar.
If they are in fact the same diamater i'm sure honda will have what you need.'
Maybe contact the people at ST to help you out.
Old Jan 8, 2005 | 11:12 AM
lemansteve's Avatar
Default Re: sway bar hardware source? (gunnis)
Yeah, the ST bar has a larger diameter. I doubt Honda would have any of the parts i'm looking for, since they are all aftermarket. Plus, the parts i need are used for mounting the bar in non factory-mount places. I guess ill just have to call ST...
swizz977
Suspension & Brakes
25
Aug 2, 2012 11:27 AM
energ3tic2
Northern California (Sales)
Apr 17, 2007 12:53 PM
delspool
Suspension & Brakes
Feb 20, 2006 04:46 PM
randallfoxjr
Dec 12, 2005 11:03 PM
crazy_ham
Mar 16, 2003 06:27 AM
