Turbo XS DSBC not working....
I have a turbo xs dual stage boost controller and when I switch to the second stage its not holding boost. The first stage works fine with no problems at all. The only thing that I can think of is the switch on the second stage is some how leaking. Has anyone ever experienced this? It was working fine before I took my motor out.
I have...well had that boost controller on my car....i absolutly hated it. It would run 10psi one day and spike to 30 at other times....completely unreilable.
i had that problem too, found out i had a tiny hole in my vaccum line. inspect all your vaccum lines. also my dsbc i had to tighten where they are connected together cause mine was loose
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBODC4TEG »</TD></TR><TR><TD CLASS="quote">i had that problem too, found out i had a tiny hole in my vaccum line. inspect all your vaccum lines. also my dsbc i had to tighten where they are connected together cause mine was loose
I'm pretty sure its not my vaccum line because it boost fine on the first setting. Its only when I switch to the second setting.
i too had that same problem low would hold fine then switch to high and i hit boost cut at 19 pounds on my hondata. when i returned it turbo xs looked it over and found it to be faulty . good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg »</TD></TR><TR><TD CLASS="quote">It could be the adjustment screw on the second stage leaking.... unscrew it all the way the check the the seal.</TD></TR></TABLE>
Thanks I try that out and see if it works.
boostmywankle
Jun 27, 2008 01:36 PM
snake01
Jul 6, 2005 01:30 PM
