anyone relocate there battery in a 5th gen?
Old Jan 7, 2005 | 11:49 AM
coupon's Avatar
Default anyone relocate there battery in a 5th gen?
i need to relocate it to free up space for IC piping and such.
which hole did u go through the firewall in and pics would be nice
Old Jan 7, 2005 | 12:51 PM
98TypeSH's Avatar
Default Re: anyone relocate there battery in a 5th gen? (nlc)
Remove the underhood fuse box. Right underneath that should be the big rubber seal that goes into the cabin that would feed right ontop/around the ECU. You can pull up your carpeting and side panels to run this all the way back. Thats what i did when i had a stereo like 2 years ago.
Old Jan 7, 2005 | 02:42 PM
coupon's Avatar
Default Re: anyone relocate there battery in a 5th gen? (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">Remove the underhood fuse box. Right underneath that should be the big rubber seal that goes into the cabin that would feed right ontop/around the ECU. You can pull up your carpeting and side panels to run this all the way back. Thats what i did when i had a stereo like 2 years ago.</TD></TR></TABLE>
cool, ill look under my fuse box today. i found another hole behind the cruise control as well
Old Jan 7, 2005 | 03:15 PM
PrettyLude's Avatar
the hole underneath the fuse box works good
Old Jan 8, 2005 | 02:29 PM
coupon's Avatar
Default Re: (PrettyLude)
no pics?
Old Jan 8, 2005 | 02:55 PM
BrokeLude's Avatar
Default Re: (nlc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nlc &raquo;</TD></TR><TR><TD CLASS="quote">no pics?</TD></TR></TABLE>
Old Jan 8, 2005 | 04:56 PM
UA6 BALLER STATUS's Avatar
Default Re: (BrokeLude)
I say just get a light weight battery..... Its less work.
Old Jan 8, 2005 | 05:13 PM
revlimitx04's Avatar
Default Re: (Type SH)
The way I did my relocation was in the trunk, and i just ran the wire down the inner frame and zip tied to wire. If you ever have a seriuos audio system the power wire inside the car would affect it by distortion. Id suggest grounding your factory ground battery cable and then run an extension power cable down the frame (18'fter 2ga.) thru the bottom of the trunk fool, either thru the water drainage holes or drill a new hole and coat it with tape or rubber, so your power wire never grounds out. then take a new negative cable (2-4fter and ground it to the frame, or solid trunk floor.
PnoyJeff
Oct 23, 2006 02:10 AM
TorquelessB16
Jun 4, 2006 11:04 AM
lakerschamp2000
Jul 15, 2004 05:02 PM
trooper0641
Jan 2, 2004 10:09 PM
