Purpost of TDC
Old Jan 7, 2005 | 09:22 AM
Jdmglenn's Avatar
Default Purpose of TDC
what is the purpose of putting the motor to TDC when you are going to take off the head??? i mean wouldnt u have to reset it all to TDC anyways??
Old Jan 7, 2005 | 11:47 AM
b18bturbo's Avatar
Default Re: Purpose of TDC (JdmGlenn)
the reason you want to set the head and the cams at tdc is to align everything up incase you move something which can cause valve damage. bent valves
Old Jan 7, 2005 | 02:42 PM
PrettyLude's Avatar
you are correct Viren
Old Jan 15, 2005 | 04:35 PM
EK FLY's Avatar
Default Re: (PrettyLude)
so how is it or how do u put the engine at tdc how do u know wich cylinder to put it up or something I replace pistons 2 days ago and I'am not sure if the engine is aligned with the cams
Old Jan 15, 2005 | 05:47 PM
sporkcrx's Avatar
Default Re: (racing_beat)
Buy a helms
You'd also have to tell us what engine it is.
Old Jan 15, 2005 | 08:37 PM
BoostedJeff's Avatar
Default Re: (sporkcrx)
there is a mark on the crank that you line up to put the number 4 and 1 pistons at the top most point, and there are 2 marks on your cam gears (if its a DOHC) that you line up. walla
Old Jan 15, 2005 | 09:56 PM
engine_runner's Avatar
there should be hash marks on the crank pulley and on the plastic timing belt cover theres another mark. also on the cam it should say top and hte hash marks on the cam gear should be leveled with the head. becarefull if you dont know how to i suggest rtfb.
Old Jan 15, 2005 | 10:36 PM
PrettyLude's Avatar
is it top or up? i think its up
Old Jan 16, 2005 | 12:09 AM
Jdmglenn's Avatar
i found out
theres a white mark on the crank pull thats away from a bundle of 3 marks, the white one is TDC
Old Jan 16, 2005 | 06:54 AM
EK FLY's Avatar
Default Re: (JdmGlenn)
engine is a b18c1
Old Jan 16, 2005 | 08:28 AM
man's Avatar
man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmGlenn &raquo;</TD></TR><TR><TD CLASS="quote">i found out
theres a white mark on the crank pull thats away from a bundle of 3 marks, the white one is TDC </TD></TR></TABLE>
or stick a long extention down the # 1 or 4 spark plug hole and wait till it goes to the highest piont !
Old Jan 16, 2005 | 09:37 AM
Default Re: (ROLINONDUBS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ROLINONDUBS &raquo;</TD></TR><TR><TD CLASS="quote">
or stick a long extention down the # 1 or 4 spark plug hole and wait till it goes to the highest piont !</TD></TR></TABLE>
Old Jan 16, 2005 | 10:30 AM
Combustion Contraption's Avatar
dial caliper = true TDC point.
B18 civic
Feb 22, 2022 12:23 PM
nutz4vette
Sep 3, 2018 09:14 AM
user 23852445234524
Honda CR-V & Element
Jan 26, 2016 03:46 AM
White_EK49
Apr 24, 2006 11:42 PM
sshaikh01
Apr 28, 2003 03:18 PM
