Rebuilding a hydrolocked engine?
Old Jan 7, 2005 | 08:40 AM
hawaiianbro's Avatar
Default Rebuilding a hydrolocked engine?
Hey guys, my friend hydrolocked his Integra GS.... I was wondering what process I would take to get it running again? Like would I need to replace all the internals? ECU? I just want to find out if its gonna be way too much trouble to rebuild it then to buy another engine!
Any help is appreciated!
Thanks,
Kaleo
Old Jan 7, 2005 | 12:22 PM
DontSayThat's Avatar
Default Re: Rebuilding a hydrolocked engine? (hawaiianbro)
Can't really rely on me. But im pretty sure your going to need to pretty much replace the bottom end. I don't think you need to replace the Crank, But pretty sure about, sleeves, Rods, Pistons, Bearings, Rings, So on and so forth.
Old Jan 7, 2005 | 06:45 PM
T.J.'s Avatar
Default Re: Rebuilding a hydrolocked engine? (DontSayThat)
well in you hydrolocked your motor, Most likely your bottem end is screwed. Just depends how fast you shut the motor off when you hydro locked it. Chances are you bent a rod or two whinch also will throw off the ballance of the crank. I you are going to rebuild i would just start from scratch. New rods, bearings, hone, piston rings, and if you have the money i would look at upgrading the pistons.
ITR.#1446
Jul 22, 2008 09:34 PM
AlienKrOZ
Apr 27, 2006 08:54 AM
allanonjj
Jun 16, 2005 09:29 AM
N1Spec
Oct 20, 2002 08:06 PM
Sh4rky
May 24, 2002 08:37 PM
