Timing belt changing question
Old Jan 7, 2005 | 08:16 AM
OzWolfbane's Avatar
Default Timing belt changing question
Hi when changing timing belt it mentions 2 belts in parts...
13405-PT0-004 BELT, BALANCER TIMING (UNITTA) $33.14
14400-P13-014 BELT, TIMING (155YU24 A-555) $48.60
which one do i change
its a JDM engine H22a for a 93 prelude
ta
Old Jan 7, 2005 | 08:30 AM
Hawkze_2.3's Avatar
Default Re: Timing belt changing question (OzWolfbane)
Timing belt is just that---timing belt. Your balancer belt is a secondary belt that rotates 2 shafts in the block to reduce vibrations. If you remove this belt, you will get a couple more hp, but have slightly greater vibration.
Anyhow, this is the timing belt---->14400-P13-014 BELT, TIMING (155YU24 A-555) $48.60
Old Jan 7, 2005 | 09:01 AM
PrettyLude's Avatar
change the autotensioner too, or convert it to the manual one
Old Jan 7, 2005 | 11:06 AM
Daily Interlude's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">change the autotensioner too, or convert it to the manual one</TD></TR></TABLE>
^^^^agreed. Don't be like me. Enjoyed VTEC for a day and then the tensioner fails!
Old Jan 7, 2005 | 11:11 AM
revlimitx04's Avatar
Default Re: (Daily Interlude)
A few months back i did my timing belt maintanence.. id suggest going to http://www.prostreetonline.com and ordering the kit to change it, expecially a 93, youll want a new waterpump while your down there, and the tensioner, and balancing belt and timing belt if your going to do the job right, your car wont have down time in that area for years to come.
I think the kit for a 5th gen was near 300 something, and a valve cover gasket kit, not neccasary but for 20 bux while its off what the heck... anyways prospeed.
Modified by revlimitx04 at 8:12 PM 1/7/2005
Old Jan 7, 2005 | 11:25 AM
Hawkze_2.3's Avatar
Default Re: (revlimitx04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revlimitx04 &raquo;</TD></TR><TR><TD CLASS="quote"> id suggest going to http://www.prospeedonline.com </TD></TR></TABLE>
That doesn't even go anywhere. You must mean http://www.prostreetonline.com
Old Jan 7, 2005 | 11:45 AM
SKDRCR's Avatar
Default Re: (Hawkze_2.3)
Inspect the balancer belt, if the teeth look worn or it has
any oil on it ot anything I would replace that as well
Old Jan 7, 2005 | 11:47 AM
Hawkze_2.3's Avatar
Default Re: (SKDRCR)
"I got 2 guns...one foh each of ya"
Old Jan 7, 2005 | 01:24 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
"I got 2 guns...one foh each of ya"</TD></TR></TABLE>
Say when
Old Jan 7, 2005 | 05:14 PM
That doesn't even go anywhere. You must mean http://www.prostreetonline.com</TD></TR></TABLE>
Thanks, ya your right its http://www.prostreetonline.com
I fixed it on the previous post.
imadigitalgod
Aug 18, 2023 08:01 PM
Comp97GSR
Dec 30, 2022 12:10 PM
eg6T
Aug 14, 2005 02:35 AM
