DOHC ZC turbo setup?
Old Jan 6, 2005 | 09:16 PM
MugenFlaredCRX's Avatar
Default DOHC ZC turbo setup?
I posted before about what I could use for my fuel management on my crx. i'm planning on running 10psi or less. i have a 255lph pump and pressure regulator. i was looking at the greddy e-manage unit, but i dont know exactly what else i need to make this work. any help would be great. thanks
josh
Old Jan 6, 2005 | 09:34 PM
murmur9's Avatar
Default Re: DOHC ZC turbo setup? (MugenFlaredCRX)
do a search on emanage. hit up the FI section. emanage CAN work on STOCK injectors....but i would only do that if you were running the 5.5psi the kit's wastegate is set at. well now that i think about it...i remember a mod on the site that said he used a walbro 190, stock injectors, emanage and was driving on 7-8psi daily.
Get bigger injectors. Might wanna use some old DSM ones if your running low on cash. walbro 255 pump is a good choice.....you will be able to use emanage i think....but it might be better to use like a vafc hack or whatever it's called. You could set it to your pref with it rather than the emanage.just make sure you get it tuned. hope that helps a little
Old Jan 6, 2005 | 09:45 PM
95HatchZC's Avatar
Default Re: DOHC ZC turbo setup? (murmur9)
thezcr.com
Old Jan 6, 2005 | 09:48 PM
SC0TT's Avatar
I'd suggest a pm6 w/ turboedit if youre running obd0.
Dont do the afc hack..**** sucks.
Old Jan 6, 2005 | 10:09 PM
blackeg's Avatar
Default Re: (SC0TT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SC0TT &raquo;</TD></TR><TR><TD CLASS="quote">I'd suggest a pm6 w/ turboedit if youre running obd0.
Dont do the afc hack..**** sucks.</TD></TR></TABLE>
i second this
Old Jan 9, 2005 | 09:02 AM
Swapped_EG's Avatar
just a word of advise, don't do zc turbo. ZC's don't like turbo's. He put the turbo setup on and about a week later his zc crx turbotook a big **** on him while he was running an ls powered ef. just wanted to let you know. you'll prolly still do it so good luck.
Old Jan 9, 2005 | 09:39 AM
blackeg's Avatar
Default Re: DOHC ZC turbo setup? (Swapped_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swapped_EG &raquo;</TD></TR><TR><TD CLASS="quote">just a word of advise, don't do zc turbo. ZC's don't like turbo's. He put the turbo setup on and about a week later his zc crx turbotook a big **** on him while he was running an ls powered ef. just wanted to let you know. you'll prolly still do it so good luck. </TD></TR></TABLE>
and on the opposite end of this, i know someone who ran sloppy amounts of nitrous on a zc, only to turbo it right after. he was putting down 230 whp stock internals and made quite a few 12 second passes before he pulled the motor out in favor of a built block. with the head off, the cylinder walls had very little scoring and the pistons did not show any signs of melting or detonation.
Old Jan 10, 2005 | 03:02 PM
Swapped_EG's Avatar
Default Re: DOHC ZC turbo setup? (blackeg)
that sounds good, but my buddies zc could barely hold 8 psi for more than a week. and it still couldn't take my eg. but tell your friend i admire him for doing that to a zc.
Old Jan 13, 2005 | 01:21 AM
liam821's Avatar
25 Year Member
What are you talking about? I made 330whp on pump gas on my 1.6litre dohc ZC. The dohc ZC motor loves turbos - makes really good power. A nice 50trim and a good set of turbo cams, the zc flys. Stock or built.
You're friend just had a bad motor to start with. Dont let one incident distroy the love for the little honda motor that could.
liam
Old Jan 13, 2005 | 03:37 AM
quis23's Avatar
&lt;-- 2 + years @ 6-10 psi and my zc is still going strong.
any motor is gonna take a **** of you if don't know what you're doing.
Old Jan 13, 2005 | 08:17 AM
Swapped_EG's Avatar
Default Re: DOHC ZC turbo setup? (liam821)
thats good, i guess he just got a bad motor to start with. and i don't hate on anything honda. i just don't know much about zc's and i've heard they can't take the boost. but i guess i was proven wrong. thanx. you learn something new everyday!
Old Jan 13, 2005 | 02:13 PM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swapped_EG &raquo;</TD></TR><TR><TD CLASS="quote">thats good, i guess he just got a bad motor to start with. and i don't hate on anything honda. i just don't know much about zc's and i've heard they can't take the boost. but i guess i was proven wrong. thanx. you learn something new everyday!</TD></TR></TABLE>
InvaderTrax
10
Aug 5, 2007 09:36 AM
MugenFlaredCRX
Jan 13, 2005 09:24 AM
crxhybrid85
Jul 5, 2004 12:46 PM
RustyRex
May 26, 2003 07:14 PM
zexdrex
Jun 14, 2002 06:55 AM
