1992 honda civic torque bolt chart
thanks anyway dude. my dad can check on the database at the garage tmrw morning, but it was worth a shot. will just have to wait. i'm down to 1 left for today, so have a good one.
When you install the cam cap cover back on be sure to torqe the 10mm bolts to 7 Ft lbs first
and then torqe the 12 mm bolts to 20 ft lbs in the following sequence be very careful not to torqe them too fast or you will snap a bolt off like i did. do it very slowly.
9 5 1 3 7
8 4 2 6 10
When you are torqing down the headbolts with Honda Head bolts you want to do this in a 3 step form
step one 21 ft lbs then back off 1/2 a turn
step two 42 ft lbs then back off 1/2 a turn
step three 63 ft lbs of torqe and your done
this must be done in the following sequence
9 5 1 3 7
8 4 2 6 10
thanks to jdmlyfestyle
Modified by racing_beat at 10:12 PM 1/6/2005
9 5 1 3 7
8 4 2 6 10
9 5 1 3 7
8 4 2 6 10
onwisconsin81
Apr 5, 2010 01:25 AM
