Any Info on a B20 in 88-91 crx??
Im getting ready to start a new project and wanted to see if anyone had some info. Ive got a 89 CRX Si and am thinking of droping a B20.
Anyone have any info or websites with info on this swap?? Please throw the info my way.
Thanks alot! !
Thanks alot! !
It's the same as any other B series swap into an EF. You'll need an aftermarket mount kit and shift linkage, B series tranny (other than CRV) if it's hydro you'll want to get the HASport mount/conversion kit, Integra LS intake manifold and a 90-93 Integra driver's side mount bracket. The amount of wiring will depend on what OBD you go with. OBD1 would be best and will require an OBD0 to OBD1 adapter harness, 4 wire O2 sensor and a little added wiring. Just read up on general B series swap info in any 88-91 Civic or CRX. If you can't find exact specifics on a B20 although you should be able to, following an LS swap would be basically the same thing.
The only REAL difference between this swap and any other B-series swap is getting the parts you need. Unlike other B-series swaps, there is no swap package you can buy. You must separately buy the engine, transmission, ECU, intake manifold assembly, and mount brackets.
1990CrxSi
21
Aug 6, 2002 05:18 AM
