Neptune tuned dohc ZC dyno w00t!
***UPDATED ADDED VIDEO - look below***
I finally got my Neptune ECU installed and dyno tuned by Cortney Green in the snowy state of Utah.
We did a total 27 or 28 dyno runs, tuning pump gas and race gas maps. We used a p28 vtec ecu, with vtec enabled even though i have a non-vtec motor. We swap over to the vtec maps at 5000rpms. The vtec maps can run better timing and have much better fuel resultion.
We couldnt get the my boost any higher then 24psi - and even at 24psi the boost was falling off on the topend (you can see it in the dyno plot below - look at the difference between the pump gas and race gas map - the pump gas map keeps building power while my race gas dyno just falls off). I was hoping to break 400whp but we couldnt get the boost high enough. We figured at 32psi we would of put down 470whp. Next time!
I put down 330whp and 240torque on 91 octane pump gas at 20psi. And 380whp and 280 torque at 24psi on 112octane race gas. Im not super happy with the race gas output because we couldnt get the boost any higher. But 330whp on pump gas is awesome!!
327whp 239 torque @ 20psi on 91 octane pump gas
369whp 279 torque @ 23-24psi on 112 octane race gas (the best looking highboost dyno we made)
old engine pix - ive since cleaned up all the loose wires and hoses.
the hooptie
setup:
3rd gen dohc ZC (obd1)
Golden Eagle sleeved block
75mm std bore 9:1 Wiseco pistons
Crower billet rods
hks metal headgasket
arp headbolts
JG Pro-series race cyl head
JG 1001 race cams
JG cam gears
60trim t3/t4 .63ar stage 3 turbo
custom intake and exhaust manifolds
64mm bored GSR throttle body
MSD digital 6plus ignition and coil
ngk plugs and wires
880cc injectors
Neptune ECU
3bar MSD map sensor
precision FMIC
liam821 piping and downpipe
hydro ZC tranny with Cusco LSD
Id like to thank Cortney Green for all his help and for the awesome tuning. Car runs like a dream now. Also a big thanks to Javier at JG Engine Dynamics for building me an awesome cyl head. Also a shoutout to my friends over at Prostreetonline.com for all the help getting me most of my parts, and to ben at importparts.com. Big thanks to Jason over at Phantom motorsports for letting us use his dyno for the afternoon - good luck next year in ProAM with the del Sol i wanna see 160mph!! Id also like to thank all the other d-series ninjas on this board, couldnt of done it without all your help and inspiration.
Dyno Video
http://liam821.com/pix/video/l...5.wmv
liam
Modified by liam821 at 8:34 PM 1/8/2005
Modified by liam821 at 6:04 PM 1/12/2005
Modified by liam821 at 7:14 PM 3/9/2005
the hooptie
setup:
Crower billet rods
arp headbolts
JG 1001 race cams
JG cam gears
ngk plugs and wires
880cc injectors
Neptune ECU
3bar MSD map sensor
precision FMIC
Dyno Video
liam
Glad to hear everything worked out and you made it home safely... Congrats man...
Cortney told me he was using the vtec maps because he was expecting to tune above 8000rpm... You guys decided not to go above 8?
Awesome! Feel free to post this on http://neptune.evans-tuning.com in the NepTune'd forum.
Get that 5 bar goin!
Props on a great numbers. I stopped by there just after your last dyno run with some friends. Its cool to see something different and with great success.
When do you plan on coming back to re-tune? And have you been able to figure out yet why you're not making more boost?
my pics from that night
all i have to say is WOW, that thing sounded crazy, open downpipe
liam, it was great meeting you, hopefully iw ill see ya next time ya stop by haha.
some pics of the car on the dyno
last one, cort doin a pull.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockredej1 »</TD></TR><TR><TD CLASS="quote">
[/img]</TD></TR></TABLE>
Is it just me, the angle, or...does the pipe that come of the external wastegate stick out through the hood??? I hope i'm seeing things....if not...that's ******* awesome
EDIT: ok, weird, first set of pics, no pipe on wastegate, then second pic., when it was on the dyno there is a pipe of the wastegate, so i know i'm not seein ****....i need info....lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buck02 »</TD></TR><TR><TD CLASS="quote">congrats on the tune man i was suppose to be there helping court pull all the **** out my car for the cage im sure you saw that hell hole project
but good luck with the zc </TD></TR></TABLE>
your buck? im corts intern and all i have to say is your car is beatiful
