headlight chime coming on when lights off.
Old Jan 6, 2005 | 03:43 PM
aimdude's Avatar
Default headlight chime coming on when lights off.
first time poster and i could use a little help.
i have a 97 honda accord and this afternoon I was getting out of my car and my headlight chime came on when the door was opened even though no lights were on.
i have checked headlights, brights, parking lights, turn signals, even checked the position of the ignition after i remove the keys. also checked the dome lights. nothing seems to make a difference and i know this chiming wasnt happening before.
i'm paranoid something could drain the battery and im not aware what. does anyone have any ideas what else might be causing this?
Old Jan 6, 2005 | 04:04 PM
Chiovnidca's Avatar
Default Re: headlight chime coming on when lights off. (aimdude)
Could it be the key in ignition chime? Sometimes the switch sticks.
Old Jan 6, 2005 | 04:17 PM
aimdude's Avatar
Default Re: headlight chime coming on when lights off. (Chiovnidca)
if that is the case the what would be the necessary remedy?
Old Jan 7, 2005 | 06:25 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aimdude &raquo;</TD></TR><TR><TD CLASS="quote">if that is the case the what would be the necessary remedy?</TD></TR></TABLE>
The first thing I do is inspect the ignition switch and pick out any junk that shouldn't be in there. Then try a little wd-40 to loosen it up.
Old Jan 7, 2005 | 06:39 PM
fw190bvi's Avatar
are they different??
i found out that the corner bulbs, door chime, and interior lights all work off of the same 7.5 fuse under the hood...of course i have at least 1 of my 4 corners bulbs burnt out now, and i go went through about 3 fuses in a week.....could that be a short or something??
OT: hows the civic projects coming??....DFH was disabeled, so no updates
Old Jan 8, 2005 | 03:39 AM
Chiovnidca's Avatar
Default Re: headlight chime coming on when lights off. (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">
OT: hows the civic projects coming??....DFH was disabeled, so no updates</TD></TR></TABLE>
Havn't done much to it in the last couple months. New thread is in my sig.
Honda Sport
Jun 23, 2009 07:21 PM
jArceo
Feb 14, 2006 11:25 AM
stupidwhitecat
Nov 5, 2005 04:26 AM
