mini me start to lose coolant
my mini me lasted for a year now with no problem, still runs strong but the problem is i lose coolant like every week if i go up moutains like going to the casino or long distance drive. all hoses are good, i dont see any leaks on the ground or on the motor. the timing belt is clean so the waterpump should be fine. the other thing is the head gasket, do u guys tihnk it can cause the car to lose up coolant.
help me out. give me some possible ways so i can check it out.
Well not much help but the had gasket would be blown, as said aboce check if theres white smoke. check to see if there is oil,coolant mix on the dipstick, and pull you plug wires uot and see if there anything in there. but most likely the gasket just blew, possibly not torqued down the right way??
White smoke will definitely tell you if you have a bad head gasket. If it's bad, the coolant will get into the chambers and ofcourse, it burns white. Have someone stand behind you car and tell you if white smoke is coming out when you rev it.
If you don't see any coolant anywhere around the block or on the ground, this is probably your best bet. Good luck
i have white smokes only when i just start up my car up which that is normal when engine is cold after when engine is warm no more white smoke. the dip sticks just have oil on it and the spark plugs is dry.
damn its only 1 year and my head gasket is bad. is it becuz the car is running too rich. the car still drives smooth and power. it dont even overheat, just that 1 or 2 later i lose coolant but not much. prolly half a liter of coolant
sidewayz32
Oct 16, 2005 02:19 PM
BOOSTEDgreeneg
Jul 8, 2004 01:34 PM
