Cheap HID conversion, is it good or not?
Old Jan 6, 2005 | 12:05 PM
a1320honda's Avatar
Default Cheap HID conversion, is it good or not?
Im sure i know the answer to this but i was curious if these were worth the money, just another cheap ebay gimmick im sure but i thought id check, anyone use one of these kits?
http://cgi.ebay.com/ebaymotors...=WDVW
Old Jan 6, 2005 | 12:19 PM
eg92b16a2's Avatar
Default Re: Cheap HID conversion, is it good or not? (a1320honda)
read this
https://honda-tech.com/zerothread?id=1104891
Old Jan 6, 2005 | 12:24 PM
a1320honda's Avatar
Default Re: Cheap HID conversion, is it good or not? (eg92b16a2)
ya i read that
Old Jan 6, 2005 | 12:30 PM
Mario.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda &raquo;</TD></TR><TR><TD CLASS="quote">ya i read that</TD></TR></TABLE>
Then why the **** are you even asking if you know it's gonna be absolute ****?
Old Jan 6, 2005 | 12:32 PM
eg92b16a2's Avatar
sorry didn't click on your link..
it looks like higher wattage bulbs with upgraded wires and relays to handle the voltage.
i don't think it is HID..
I thought HID are not halogen.
Halogen is regular bulbs
Old Jan 6, 2005 | 12:45 PM
CivicSiR's Avatar
its not HID
its crap
Old Jan 6, 2005 | 12:51 PM
a1320honda's Avatar
Default Re: Cheap HID conversion, is it good or not? (Mario.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario. &raquo;</TD></TR><TR><TD CLASS="quote">
Then why the **** are you even asking if you know it's gonna be absolute ****?</TD></TR></TABLE>
Wow, i didnt know they talked about that particular "hid" system in that post DICK. simple question asked, is it really crap, you dont know, you havent bought a set, so why the **** are you replying. why does everything have to have a purpose, i want to know for my general knowledge, not cause im gonna go out and buy stock in the ****** company. thanks for the reply though! i dont know alot about HID systems and im trying to learn. but i guess you know every ******* thing in the world huh?
Old Jan 6, 2005 | 01:03 PM
Mario.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda &raquo;</TD></TR><TR><TD CLASS="quote">Wow, i didnt know they talked about that particular "hid" system in that post DICK. simple question asked, is it really crap, you dont know, you havent bought a set, so why the **** are you replying. why does everything have to have a purpose, i want to know for my general knowledge, not cause im gonna go out and buy stock in the ****** company. thanks for the reply though! i dont know alot about HID systems and im trying to learn. but i guess you know every ******* thing in the world huh?</TD></TR></TABLE>
It's $70... compare that to the cost of a real HID setup. If that setup really worked for $70, then why would people spend $400 on projector retrofits? It's called common sense... you get what you pay for.
Old Jan 6, 2005 | 01:05 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Dont you know, everyone on H-T knows everything!!!!
Old Jan 6, 2005 | 01:17 PM
Unsivil_audio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario. &raquo;</TD></TR><TR><TD CLASS="quote">It's $70... compare that to the cost of a real HID setup. If that setup really worked for $70, then why would people spend $400 on projector retrofits? It's called common sense... you get what you pay for.</TD></TR></TABLE>
True its not real HID but it is the same Idea in the sense that stepping up the power to the bulbs to produce more light. I might try out some of these, the thing you really have to be aware of is higher wattage halogen bulb produce more heat and could melt your headlight housings whereas HIDS are lower wattage and produce less heat but more light. Either way, its bound to be an improvement over stock.
Old Jan 6, 2005 | 01:24 PM
Mario.'s Avatar
Default Re: Cheap HID conversion, is it good or not? (Unsivil_audio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unsivil_audio &raquo;</TD></TR><TR><TD CLASS="quote">True its not real HID but it is the same Idea in the sense that stepping up the power to the bulbs to produce more light. I might try out some of these, the thing you really have to be aware of is higher wattage halogen bulb produce more heat and could melt your headlight housings whereas HIDS are lower wattage and produce less heat but more light. Either way, its bound to be an improvement over stock. </TD></TR></TABLE>
More light? Did you not read a single thing in the thread that was posted here?? I could a flashlight pointed out the side of my window to assist my stock headlight system... that must mean my lighting system is better than yours, because I have more light even though it has no sense of aim or direction right???
Either way, it's an absolute waste of your money and you'd be much better off with some PIAA's or something that have been tested and tried and true.
Old Jan 6, 2005 | 02:09 PM
eg92b16a2's Avatar
but piaa's are higher wattage too... you will need a new harness so that you don't burn you stock harness.. there is a guy on ht that sells harness for higher wattage bulbs..
i would search but time for me to go home...
damn MARIO.. chill he was just asking a question, you don't have to berate (sp)...
everybody has to start somewhere.
Old Jan 6, 2005 | 02:13 PM
8krdline's Avatar
thats not an hid kit anyways. it still has the filament bulb while hid bulbs use gas. looks more like the catz product that would just brighten your existing bulbs
Old Jan 6, 2005 | 02:16 PM
ecahatch's Avatar
Senor Miembro
dont buy it...
Old Jan 6, 2005 | 02:24 PM
00Red_SiR's Avatar
All Motor Mentor
Changing out the stock bulbs with a higher power bulb is no different than changing the 60w bulb out for a 100w bulb in a table lamp. The light will still be focused the same way as before since the shielding and reflectors are still the same and in the same place, but the room will be brighter and vision will be enhanced. As long as the bulb wattage doesn't exceed the wiring's capabilities, it's a great way to improve visibility.
Old Jan 6, 2005 | 07:21 PM
Mario.'s Avatar
Default Re: Cheap HID conversion, is it good or not? (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">Changing out the stock bulbs with a higher power bulb is no different than changing the 60w bulb out for a 100w bulb in a table lamp. The light will still be focused the same way as before since the shielding and reflectors are still the same and in the same place, but the room will be brighter and vision will be enhanced. As long as the bulb wattage doesn't exceed the wiring's capabilities, it's a great way to improve visibility.</TD></TR></TABLE>
Then why does an H4 HID not work as you state? All it is a brighter bulb... it should just be like the stock lighting but brighter? Doesn't appear to be...
Old Jan 6, 2005 | 08:59 PM
00Red_SiR's Avatar
All Motor Mentor
It's because the bulb itself and element is totally different in shape and size, therefore the bulb light focuses differently on the stock reflector.
I was only referring to the kit that the original poster was asking about which was just a higher output bulb setup, not an HID setup.
Old Jan 6, 2005 | 09:27 PM
hypoxvi's Avatar
these are not real HID's. They specifically say they have a filament. HID bulbs are filled with Xenon gas and what happens is when you turn them on the ballasts create an electric arc across the gas inside the bulb to emit light. Also, if you do decide to go HID on your car, remember that HID's only support one beam. so in otherwords, no high beams.
Old Jan 6, 2005 | 09:29 PM
Shaun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda &raquo;</TD></TR><TR><TD CLASS="quote">Im sure i know the answer to this but i was curious if these were worth the money, just another cheap ebay gimmick im sure but i thought id check, anyone use one of these kits?
http://cgi.ebay.com/ebaymotors...=WDVW</TD></TR></TABLE>
that kit looks like something out of toys-r-us
Old Jan 6, 2005 | 09:58 PM
acefabric's Avatar
Looks like someone got sent to their room early tonight by mom and dad without dessert, wahhh
Old Jan 6, 2005 | 09:59 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Cheap HID conversion, is it good or not? (hypoxvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypoxvi &raquo;</TD></TR><TR><TD CLASS="quote">these are not real HID's. They specifically say they have a filament. HID bulbs are filled with Xenon gas and what happens is when you turn them on the ballasts create an electric arc across the gas inside the bulb to emit light. Also, if you do decide to go HID on your car, remember that HID's only support one beam. so in otherwords, no high beams.</TD></TR></TABLE>
You can get halogen style bulbs that have xenon gas in them to give them a slightly higher light output. Most of those fake HID look alike bulbs you buy out there are like that. You can also get the HID kits that do have high and low beam capability.
Old Jan 6, 2005 | 10:05 PM
NathanMorris's Avatar
it's a nice idea, but eh, waste....get real HID or stick with stock, from someone who's done almost everything with lights - only "upgrade" that's worth it out of all of them, is those with 9006/9005 lights, to convert the 9006 socket to 9005. And of course a real HID upgrade.
- Nathan
Old Jan 6, 2005 | 10:18 PM
IMPORTEKNIKAEG6's Avatar
Default Re: Cheap HID conversion, is it good or not? (92Lx)
dont get those one of my boys had them and they looked just like the hyper whites its just better to get a real HID kit
Old Jan 6, 2005 | 10:37 PM
GapxGuy's Avatar
Sushi Buffet Champion
If you know about the 9006 to 9005 bulb conversion, that's basically what this kit is. 9006 to 9005 conversion generates more heat, causing wire harnesses to burn. This looks to be the same concept, but they're preparing you for what's likely to happen - wire harness burning.
FunkyFresh_EK
Lighting
Sep 22, 2011 08:06 AM
rich3sgte
Lighting
Jan 4, 2011 06:02 AM
neenreva
Lighting
Jan 23, 2009 02:37 PM
b16_madman
10
Nov 14, 2004 12:22 AM
hndarcrb18c1
Oct 23, 2003 03:04 AM
