Suspension & Brakes Theory, alignment, spring rates....
spring install
Old Jan 5, 2005 | 07:20 PM
Joon Joon's Avatar
Default spring install
aight.. i'm planning to do a spring install on my cousins 01/02 civic 4door.. i wasnt sure wat the chasis code was for the car and i couldnt find anything with just typing 2001 spring install or 2002 spring install.. i was wondering if it would be the same as eg/ek or the same as the ep??
Old Jan 6, 2005 | 06:38 AM
Joon Joon's Avatar
Default Re: spring install (vtecenjun)
bizzzuuummmpppp
Old Jan 6, 2005 | 12:42 PM
purplegsr's Avatar
It should be the same as the ep, try this DIY and there may be more info on http://www.7thgencivic.com. The link is for a strut install, but it also details how to get the everything apart and off, put the new springs back on, and bolt it all up. It won't be the same as the eg/ek because of the change to mccpherson struts in 01+ civics.
http://www.hondatuningmagazine...nsion
You can skip steps 7-16 if you aren't replacing the struts.
Old Jan 6, 2005 | 12:58 PM
Tyson's Avatar
Default Re: spring install (purplegsr (Exospeed))
wow, thats a really good right up. man, i pity those civic/rsx owners who have to deal with the macpherson setup. thats a pretty neat idea on how to secure the new insert. i was wondering what koni meant by their "patented" method.
Old Jan 6, 2005 | 01:20 PM
purplegsr's Avatar
Default Re: spring install (Tyson)
Yeah, I agree, I definitely take the EF/DA/DB/DC/EG/EK suspensions for granted when it comes to swapping out springs and shocks. That looks like hell for a DIYer.
For the original poster: it shouldn't be too bad if you are just putting in new springs, but by the looks of that article, that civic had some very tired shocks after only 22k miles.
Old Jan 6, 2005 | 01:24 PM
Joon Joon's Avatar
thanks purplegsr.. yeah i've done my eg and an ek but i havent seen or done a spring install in the new civics.. i havent even looked under a newer civic.. thanks again.. i'll probably be doing this to my cousins car soon..
EJ8 GSR-T
Suspension & Brakes
Jan 25, 2007 05:56 PM
rmiles87
Suspension & Brakes
Oct 7, 2005 06:45 AM
vinuneuro
Mar 4, 2004 04:20 AM
Isaac
Sep 25, 2001 02:58 PM
OneThirtyEight
Sep 8, 2001 04:42 PM
