***!!!***!!!***!!!***!!!***!!!swimming pool in my car!!!***!!!*****!!!***!!!***!!!***
Old Jan 5, 2005 | 06:37 PM
Phrost's Avatar
Default ***!!!***!!!***!!!***!!!***!!!swimming pool in my car!!!***!!!*****!!!***!!!***!!!***
EVERY TIME IT RAINS MY CRX GETS A POOL OF WATER INSIDE BUT ONLY ON THE PASSENGER SIDE HOW CAN I STOP THIS??
Old Jan 5, 2005 | 07:07 PM
doublethink's Avatar
Default Re: ***!!!***!!!***!!!***!!!***!!!swimming pool in my car!!!***!!!*****!!!***!!!***!!!*** (eric16122
your thread topic is ******* annoying.
you have a leak, its either the windsheild seal, or the door jam moldings...
if you cant find it take it to a good glass place and have them help you hose the car down with you in it to isolate the leak.
Old Jan 5, 2005 | 07:10 PM
limpy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">
if you cant find it take it to a good glass place and have them help you hose the car down with you in it to isolate the leak.</TD></TR></TABLE>
amen.... and ditto.
Old Jan 5, 2005 | 07:18 PM
bagpipe goatee's Avatar
its probably rusted where the raingutters meet your windshield. really common, i went ghetto and pulled out the rain gutter covers, cut out the rust (have 2 inch by half inch at least hole on each side) and filled with clear silicone till i can afford to pull my windshield. works better than nothing.
Old Jan 5, 2005 | 11:49 PM
Phrost's Avatar
I must ask what is so annoying about caps lock r u just being a dick or whats the deal?
Old Jan 6, 2005 | 12:29 AM
rough_draft's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eric16122 &raquo;</TD></TR><TR><TD CLASS="quote">I must ask what is so annoying about caps lock r u just being a dick or whats the deal?</TD></TR></TABLE>
dick
caplocks=yelling
Old Jan 6, 2005 | 12:41 AM
EF9panda's Avatar
yeah ... that sucks .. hope you find the problem .. my solution would be find where the water drops ...wrap a bandana there ..and plan on taking a whole day to figure out the problem .. simple things make our cars so dumb ..
Old Jan 6, 2005 | 05:07 AM
WhatThaFrig's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omghi2ubbq &raquo;</TD></TR><TR><TD CLASS="quote">
caplocks=yelling </TD></TR></TABLE>
caplocks+bold=yelling real loud!
check your cowl panel(it's where your wipers are). There's a gasket in there that goes to ****.Plus there are some drain in there that get clogged.
Old Jan 6, 2005 | 08:44 AM
kid-honda's Avatar
Remove all interor panels on that side, sit inside car and have someone take a hase and slowley work from bottom of the car up and the leak will show it self and you will know exactly were it is.
Old Jan 6, 2005 | 08:54 AM
SexyAzNMami's Avatar
where is the water coming through from? I had a similar problem but the water was coming from the back lift hatch. check it out . . https://honda-tech.com/zerothread?id=1102579
Old Jan 6, 2005 | 09:57 AM
Phrost's Avatar
i think its coming in from where the tail lights mount up and drops come in from my interior light but these dont leak bad enough to get all that water in my passenger area its got to be from somewhere else
mzr0r0
Feb 2, 2008 09:09 PM
Racersky
15
Aug 12, 2006 09:33 AM
G2 Speed
10
Oct 13, 2005 09:40 PM
integraguy73
Aug 18, 2004 01:04 PM
airikkCRX
May 1, 2004 01:35 PM
