fastbrakes 11" front oem kit
Old Jan 5, 2005 | 06:32 PM
Hartattack's Avatar
Default fastbrakes 11" front oem kit
Alright so I have the Fastbrakes 11" front oem kit on my 94 Civic Dx which is non abs. I know that the kit uses Corrado rotors, but I need to know what kind of calipers it uses because I need new pads. I was very sure that they were 91 ex calipers but after ordering EBC green-stuff pads and finding out that they didn't fit I need help before I order another wrong part.
Thanks in advance,
Chris
Old Jan 5, 2005 | 06:34 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: fastbrakes 11" front oem kit (Hartattack)
e-mail Brian. Sales@fastbrakes.com
I thought it was Integra calipers, but I can`t remember.
Old Jan 5, 2005 | 06:47 PM
Hartattack's Avatar
Default Re: fastbrakes 11" front oem kit (vtecvoodoo)
Thanks I will do that, but I was just hoping for an answer tonight so I can order them soon.
Old Jan 5, 2005 | 07:05 PM
2000EM1's Avatar
I know the 11.75" Front upgrade uses 4 piston Wilwood Calipers, I don't know if that's standard on all their caliper upgrades or not.
Old Jan 5, 2005 | 07:13 PM
Hartattack's Avatar
Default Re: fastbrakes 11" front oem kit (2000EM1)
They are not wilwoods for sure, because it states that it uses an oem caliper. I am just not sure which one. They are single piston, pretty much the same as stock but much bigger.
Old Jan 5, 2005 | 07:16 PM
IM ALL BOB's Avatar
I have the 11" OEM FRONT brake kit on my 96 dx civic..and I was given Gsr Calipers when I purchased the system from brian at fastbrakes.. so it should either be gsr calipers good luck
Old Jan 12, 2005 | 12:37 AM
Dirk-EG's Avatar
The kit can be used with any Nissin caliper stating ..CL14VN <-- 14VN, most likely you'll either have the GSR calipers or the 16CL14VN calipers which come of the 5th gen Coupe D16z6/y8 (which is the? Si?)
Old Jan 12, 2005 | 07:30 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (Dirk-EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dirk-EG &raquo;</TD></TR><TR><TD CLASS="quote">The kit can be used with any Nissin caliper stating ..CL14VN &lt;-- 14VN, most likely you'll either have the GSR calipers or the 16CL14VN calipers which come of the 5th gen Coupe D16z6/y8 (which is the? Si?)</TD></TR></TABLE>
93-95 civic EX 2 door coupe.
Old Jan 12, 2005 | 09:14 AM
Dirk-EG's Avatar
Default Re: (94eg!)
Well close enough.. here its called the ESi.
DC4_MADMAN
Dec 1, 2005 09:51 AM
rudeman85
Jul 13, 2004 05:55 PM
JrCRXHF
19
Jan 2, 2004 08:16 PM
Denny317
Jul 21, 2003 11:04 AM
fastbrakes
Feb 4, 2002 02:06 PM
