Maintenance Light Turned RED in 2000 EM1
Old Jan 5, 2005 | 05:02 PM
Dstretch33's Avatar
Default Maintenance Light Turned RED in 2000 EM1
What's Up,
As you probably see in my Sig, I have an si. The car has received a full tune-up every 2500-3000 miles(air filter, oil, oil filter, etc.). When I bought the car it received the Herb Chamber's Honda 100? point inspection(meaning they replaced everything). What I am curious about is the light in the oem si instrument cluster(under the speedometer). This light has now turned red, do I have to go to the dealer to have it reset, or fixed. The car runs fine, and has received all proper maintenance....it's due for it's next tune up in 200 miles.
Anyone have this happen.......am I over reacting........does it mean anything else
O and I don't have a owner's manual
Old Jan 5, 2005 | 05:04 PM
JIDUM_Undercover's Avatar
I would take it to honda and ask them, just to make sure but if u know its well maintained and runs fine go to honda and let them reset it im sure they can do something like that.
Sam P 27's Avatar
Put a key in the indented button and it will turn to green. I usually do that after every tune up.
Edit: I wonder if your talking about what I'm thinking. Its a square-ish box that turns green or red, depending on when your tune up was done.
Also, have you looked at your manual. It will tell you.
Old Jan 5, 2005 | 05:09 PM
Dstretch33's Avatar
Default Re: (Sam P 27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam P 27 &raquo;</TD></TR><TR><TD CLASS="quote">Put a key in the indented button and it will turn to green. I usually do that after every tune up.
Also, have you looked at your manual. It will tell you.</TD></TR></TABLE>
Yes, i'm talking about the small square box under the speedometer, and I do not have an owner's manual. Thanks for the help though.
Old Jan 5, 2005 | 05:11 PM
pwrofdrm's Avatar
Calm down
It's an indicator light for when you're due for an oil change. I believe it turns red every 5k miles (don't quote me though, possibly wrong). Just stick your key or something in that little hole in the instrument cluster and it will turn green again.
Old Jan 5, 2005 | 05:16 PM
Dstretch33's Avatar
Default Re: (lax1185)
okay, I will do it tonight......when I get out of work
Old Jan 5, 2005 | 05:20 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (Dstretch33)
Is it even a light? I've been curious. I think its just a small bar that acts somewhat like a trip meter, instead of rolling #'s by, it rolls colors by. States right in the owners manual it goes...........orange @ 5000, and red @ 7000? Or something like that, I dont quite recall, and its too cold out for me to go look it up right now.
No worries guy, just press the key into the little slot and it will pop back to green.
Old Jan 5, 2005 | 05:25 PM
Dstretch33's Avatar
Default Re: (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Is it even a light? I've been curious. I think its just a small bar that acts somewhat like a trip meter, instead of rolling #'s by, it rolls colors by. States right in the owners manual it goes...........orange @ 5000, and red @ 7000? Or something like that, I dont quite recall, and its too cold out for me to go look it up right now.
No worries guy, just press the key into the little slot and it will pop back to green.</TD></TR></TABLE>
I believe your right
Old Jan 5, 2005 | 05:27 PM
jlacoy82's Avatar
71.192.16.183
Red Sox ****!! Go to the parade? I did.
lol
Old Jan 5, 2005 | 05:30 PM
Dstretch33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Red Sox ****!! Go to the parade? I did.
lol</TD></TR></TABLE>
Yup, it past right by the building I work in Downtown
Old Jan 5, 2005 | 05:35 PM
jlacoy82's Avatar
71.192.16.183
Old Jan 5, 2005 | 05:45 PM
JDMisGOOD's Avatar
Just stick the key in there...its not really a light but a multi-colored dial that slowly rotates!
Old Jan 5, 2005 | 05:47 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (JDMisGOOD)
Thanks for confirming!
lrcrx90
Apr 22, 2010 12:05 PM
DOHC4banger
Jan 22, 2008 11:08 AM
mikel_143
Nov 27, 2006 11:50 PM
cinderella925
Sep 2, 2004 11:35 AM
tx heat
Nov 10, 2003 01:17 PM
