Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
civic track chasis
Old Jan 5, 2005 | 04:08 PM
legends's Avatar
Default civic track chasis
Does anyone know if a civic EG or EK is better for track purposes only? I know that the EG chasis is lighter. Is one stiffer than the other? Is there any wheelbases or things like that that will affect a lap time?
Old Jan 5, 2005 | 04:17 PM
legends's Avatar
Default Re: civic track chasis (legends)
Can anyone help me out? I was thinking of starting a project car with one of these two chasis'. I need some advice.
Old Jan 5, 2005 | 04:28 PM
prkiller's Avatar
They are both pretty equal when all things are considered. Really, it should boil down to which one you happen to get a better deal on! Just get a good straight car to start with, either one will be fine!
And this question has been asked before!
Old Jan 5, 2005 | 04:29 PM
legends's Avatar
Default Re: civic track chasis (prkiller)
thanks
prkiller's Avatar
Oh yeah, and usually you have to wait more than 9 minutes for an answer in this forum even though it stays pretty busy!
Old Jan 6, 2005 | 06:35 AM
Littleton's Avatar
Legends, there's more parts available for the EG than of the EK.
Old Jan 6, 2005 | 07:06 AM
Civic44's Avatar
Default Re: civic track chasis (Littleton)
Once you get a cage in there, there isn't much of a stiffness difference. I went from an EF to an EK because I'm running in a series with age limits in 2005 and an EG would have "expired" in 2007. Also, it's what I found cheaper after totalling my EF.
Old Jan 6, 2005 | 01:20 PM
Lo-Buck EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Littleton &raquo;</TD></TR><TR><TD CLASS="quote">Legends, there's more parts available for the EG than of the EK. </TD></TR></TABLE>
like what?
Old Jan 6, 2005 | 02:12 PM
LudeyKrus's Avatar
Default Re: civic track chasis (Lo-Buck EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">
like what? </TD></TR></TABLE>
Well motor swaps are much easier and brake/suspension parts are easily swapped from an integra to the EG.
Old Jan 6, 2005 | 02:21 PM
AKADriver's Avatar
Default Re: civic track chasis (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">Well motor swaps are much easier and brake/suspension parts are easily swapped from an integra to the EG.</TD></TR></TABLE>
Exactly, if you plan on running these sorts of classes, the EG is closer to the DC2 and more pieces are compatible.
However if you'll be sticking with factory engine block, brakes, control arms, etc. then the EK's disadvantage dries up. You CAN get all that stuff for an EK, anyway, it's just less common since it has to come from a Civic Si.
Buy what fits your budget and the sort of racing you intend to do. Chances are it will just boil down to whatever deal presents itself first.
Old Jan 6, 2005 | 10:19 PM
D.CACO's Avatar
Default Re: civic track chasis (AKADriver)
We have an EK hatch and I dont feel that there is any distinct advantage over an EG hatch chassis.
For pure purpose sake (since we aren't talking about a particular class) I would say EG. Lighter and more aerodynamic (a few inches shorter than the EK). I am assuming you are talking about the hatchback?
:edit: Oh yeah, I forgot- The EK hatch is only DX, and so you have to replace EVERYTHING (steering rack, ALL suspension since there are NO Sway bars, etc...) which makes the EK more $$ and work.
Old Jan 7, 2005 | 10:38 PM
kurisuchan's Avatar
Default Re: civic track chasis (D.CACO)
so true it hurts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D.CACO &raquo;</TD></TR><TR><TD CLASS="quote">Oh yeah, I forgot- The EK hatch is only DX, and so you have to replace EVERYTHING (steering rack, ALL suspension since there are NO Sway bars, etc...) which makes the EK more $$ and work.</TD></TR></TABLE>
Old Jan 8, 2005 | 05:08 PM
spoon_ek9's Avatar
Default Re: civic track chasis (CERAYA!)
i would pick a EK chassis just because it got longer wheel base.
Str Pro
Jun 20, 2019 06:54 PM
Z0SARU
16
May 18, 2018 05:31 PM
blk_EK
29
Nov 26, 2006 01:28 AM
legends
Jan 5, 2005 04:06 PM
mario82686
Jun 3, 2004 07:07 PM
