Integra has a code 3 and won't rev past 3500rpm
it runs rough and when you give it full throttle it sounds really loud through the intake and won't rev past about 3500rpm.
this is on a 91 integra. Its also putting black soot all over the spark plugs.
Could a bad map sensor cause this?
I just ran the car for about 10mins and didn't get a code but the thing still won't rev past 3500rpm.
Its also smoking pretty bad and the smoke is white. But there's no bubbles or anything in the coolant.
What about a plugged cat? or messed up timing?
I also tried another map sensor and ecu and no change.
FSUseminoleEM1
Feb 19, 2010 08:34 AM
getnasty
12
Oct 26, 2009 06:54 AM
