Omnipower install need direction on preloading
Old Jan 5, 2005 | 11:04 AM
D3U1LT's Avatar
Default Omnipower install need direction on preloading
From what i hear i cant just slap them in. First what is this major preloading? what do i do? all the other topics are just a mess and i can make anything of them.
Thanks.
Old Jan 12, 2005 | 10:29 AM
D3U1LT's Avatar
Default Re: Omnipower install need direction on preloading (EJ1Racing.tk)
bump for the omni shiz i wanna get these on ryt
Old Jan 12, 2005 | 10:46 AM
chris_c's Avatar
with my teins the specify a minimum ride height which is equal to 1" [if i recall] from the bottom collar to the end of the threaded section of the damper housing. this compresses the spring some [preload, so there is always some tension on the spring even if the damper is fully extended].
i don't expect the omni's to be exactly the same. didn't you get any literature?
Old Jan 12, 2005 | 10:47 AM
khmboostedeh2's Avatar
Default Re: Omnipower install need direction on preloading (chris c)
preloading a spring is when you compress the spring BEFORE attatching it to the shock. When you buy off the shelf springs and you need to use a spring compressor to shorten the spring in order to put it on the shock. so dissassemble the coilover, and compress the spring
Old Jan 12, 2005 | 10:53 AM
Ricey McRicerton's Avatar
Default Re: Omnipower install need direction on preloading (Jeterkm02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeterkm02 &raquo;</TD></TR><TR><TD CLASS="quote">preloading a spring is when you compress the spring BEFORE attatching it to the shock. When you buy off the shelf springs and you need to use a spring compressor to shorten the spring in order to put it on the shock. so dissassemble the coilover, and compress the spring</TD></TR></TABLE>
Wrong.
Old Jan 12, 2005 | 11:02 AM
Default Re: Omnipower install need direction on preloading (Ricey McRicerton)
rats
Old Jan 12, 2005 | 11:03 AM
username taken's Avatar
since its wrong, enlighten him and anybody else please
Old Jan 12, 2005 | 11:04 AM
skip.two's Avatar
Search is your friend. use it!
https://honda-tech.com/zerothread?id=950645
Think more having people put weight on the corner of the car that you are trying to preload, then tightening the top hat down onto the spring.
Old Jan 12, 2005 | 12:18 PM
chris_c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Think more having people put weight on the corner of the car that you are trying to preload, then tightening the top hat down onto the spring. </TD></TR></TABLE>
that wouldn't do **** on the teins [unless i am looking at this all wrong].
the teins specify a torque spec for the piston rod lock nut and the upper mount sits flush againt the shock tower regardless. the only thing that would change by adjusting the piston rod lock nut on the teins would be the amount that the rubber bushings on either side of the upper mount crush. i torqued mine to the specified torque.
maybe the omni's are a very different design.
corner balancing, i still thought, was all done adjusting the lower spring perch.
Old Jan 12, 2005 | 12:20 PM
skip.two's Avatar
he's talking about Omni's, not Teins.
sikefcrx89
Suspension & Brakes
Jan 21, 2019 03:40 PM
alscrx
Honda Civic (2001 - 2005)
Mar 25, 2008 07:09 PM
AamirCWITR
Suspension & Brakes
May 8, 2007 11:59 AM
bosco500
Jun 8, 2005 05:32 AM
Beach Accord
Oct 18, 2004 03:09 PM
