idle problem put on a new TB, searched...
Old Jan 5, 2005 | 10:07 AM
TallKyle's Avatar
Default idle problem put on a new TB, searched...
well i put on a new Tb. a edelbrooke one. i put it on and i had to swap my tps from the stock tb. i am idleing at 1100 and i am throwing code 7 which is tps. i adjusted it to specs and reset the ecu, still being gay. i put on stock tb and still fucked up i don't know what to do. thanks kyle
Old Jan 5, 2005 | 10:41 AM
EFRue57's Avatar
Default Re: idle problem put on a new TB, searched... (driftn240)
this may sound like a dumb response to your question, but did you changed the throttle body gastket and make sure your intake manifold was clean of all the rest of the gasket that was stuck on? my friend swapped out throttle bodies and just forgot to clean off the remaining gastket off the intake manifold and it idled really bad untill we cleaned it off and put on a new gasket.
Old Jan 5, 2005 | 12:19 PM
TallKyle's Avatar
Default Re: idle problem put on a new TB, searched... (EFRue57)
well i cleaned it out before i had the problem. i feel really dumb now but i had put the tps in wrong hahaah. thanks though.
DO/\/\O
Jul 26, 2011 01:44 AM
Herzeleid
Jun 15, 2009 04:00 AM
emooheo
Feb 24, 2008 04:54 PM
90AcuraIntegra04
Feb 4, 2006 02:18 PM
bryan99si
11
Sep 8, 2005 09:35 PM
