y my built engine smokes?
Old Jan 5, 2005 | 08:54 AM
Prelude91siT's Avatar
Default y my built engine smokes?
ok i have a fully built block from gem. its a b20a similiar to a h23 the reason i say that is cause we use the sae rods. well when i get on it pretty hard i see smoke coming out my exhaust. i really cant tell exactly what color it is but ir looks greyish/whitish. its running n/a right now but plan to boosted in a few months. the engine as about 2500-3000 miles i guestimate any useful info will be helpful thanks.
Old Jan 5, 2005 | 08:57 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: y my built engine smokes? (Prelude91siT)
headgasket
Old Jan 5, 2005 | 10:13 AM
menkio's Avatar
Default Re: y my built engine smokes? (wantboost)
yup, headgasket
Old Jan 5, 2005 | 10:19 AM
s2kdre's Avatar
Default Re: y my built engine smokes? (menkio)
any motor is gonna smoke when you get on it. Just keep checking the oil and coolant level. But vtec is gonna consume a little oil.
Old Jan 5, 2005 | 10:23 AM
Burke's Avatar
Banned
Default Re: y my built engine smokes? (jdmhonda)
my car smokes all the time when i get on it. but it is colder out and i know its just water vapor. i have no cat and 3 inch exhaust all the way back. its just due to the vapor pressure of the water (by-product of combustion) and the outside temperature
but check your levels and you can even test your coolant to see if it has traces of exhaust gases in it
good luck
W O T's Avatar
not a lot of info there buddy
Old Jan 5, 2005 | 10:24 AM
Rod.'s Avatar
piston rings or headgasket
Old Jan 5, 2005 | 10:28 AM
dennis's Avatar
You guys can't just go spouting off "head gasket" for everything....
When I built my engine, I got the rings "inline" on cyl #1 which was doing something similar to what you describe. Pulled the slug and got everything straightened out. No problems since.
Check out your plugs, get a flash light and look down into the cylinder too. Your plugs will tell all.
You could also try different weight oils. Drain oil and check for coolant. Look for oil in coolant.
Could also be valve seals and or guides...
Old Jan 6, 2005 | 12:24 PM
yeah i just recently change my plugs and they where all white. i do smell like antifreeze sometimes but i think that could be from one of my heater hoses. i just changed my oil when i like a week ago and its black and like a qt. short already?
Old Jan 6, 2005 | 06:07 PM
JdmEKCivic's Avatar
Default Re: (Prelude91siT)
do a compression test and a leak test. that should tell you everything
Old Jan 6, 2005 | 08:20 PM
B20luda's Avatar
Default Re: (JdmEKCivic)
leakdown...tells u what u dont wanna know...
Old Jan 6, 2005 | 08:24 PM
m R g S r's Avatar
My car smokes when I get on it, white smoke. And I haven't touched the coolant since last time I changed it, the level has not changed, and compression is 210 accross.
Old Jan 6, 2005 | 08:41 PM
rice killer's Avatar
the b20's are not vtec
Old Jan 13, 2005 | 10:11 AM
ok so how do i go about figuring out what is causing it. from like what should i do first to check and last in order. thanks
Old Jan 14, 2005 | 07:54 AM
bump
Old Jan 14, 2005 | 09:34 AM
Bulldogg83's Avatar
Have you checked to see if there is any smoke that comes out of the head when you give it gas? If there is smoke coming out of there, then it's your rings. Before automatically assuming it's the headgasket is there:
1. Oil leaking from the block anywhere?
2. Oil in your coolant?
Best thing to do would just break down and do a compression/leakdown test.
Old Jan 14, 2005 | 09:56 AM
nonvtecD's Avatar
Plugs should be tan/light brown, correct me if i'm wrong but don't white plugs mean a lean condition. Like some other guy said, vtec consumes a little oil. I am assuming this is a b20vtec, though you didn't say that. How do you know you're a quart low, that's a lot for a Honda, did you measure it when you changed it or something. If your oil was black it's not your headgasket. You just running a stock dohc vtec ecu or what?
Old Jan 14, 2005 | 09:58 AM
Bulldogg83's Avatar
Default Re: (D15B7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D15B7turbo &raquo;</TD></TR><TR><TD CLASS="quote">Plugs should be tan/light brown, correct me if i'm wrong but don't white plugs mean a lean condition. If there is no coolant in your oil it's probably not headgasket, pull the dipstick. And like some other guy said, vtec consumes a little oil. I am assuming this is a b20vtec, though you didn't say that. Give us more info.</TD></TR></TABLE>
Yes if the Spark Plugs are white then it's running too lean. Now if there are specs of white on them that means the motor is detonating.....
Old Jan 14, 2005 | 10:43 AM
the oil is black. there is no coolant in the oil. my car is a non-vtec. its a b20a the first b-series made. thanks for telling my car is running lean. i dont see no leaks. should i get a leak down test down first? and if everything looks good with that. then the next thing that it could be is the head right? cause a leakdown test would check rings correct me if im wrong.
this is my 420'th post. that # is special 2 me
Modified by Prelude91siT at 3:03 AM 1/17/2005
Old Jan 16, 2005 | 06:07 PM
bump?
Old Jan 16, 2005 | 06:56 PM
Bulldogg83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude91siT &raquo;</TD></TR><TR><TD CLASS="quote">bump?</TD></TR></TABLE>
did you do a compression/leak down test?
Old Jan 16, 2005 | 08:25 PM
B20luda's Avatar
Default Re: (Bulldogg83)
a leakdown is really the only way your gonna find your problem...ckin this and that wont help..just do the leakdown and get back to us...BTW i have also built my B20a and had a simular issue, my valve seals kept poppin of the valve guides and letting oil into the cylinder...i used OEM honda seals...but apparently honda dosent use the metal jacket type seal anymore so there a newer style...all rubber and they blow...i found some metal jacketed ones and havent had a problem since...most likely isnt your prob ...but i did have that issue...
Old Jan 16, 2005 | 11:54 PM
PrettyLude's Avatar
any update on this?
Old Jan 16, 2005 | 11:56 PM
liam821's Avatar
Default Re: (B20luda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20luda &raquo;</TD></TR><TR><TD CLASS="quote">leakdown...tells u what u dont wanna know...</TD></TR></TABLE>
Yea do a leak down test and them come back and tell us whats up.
liam
lunareg
18
Dec 14, 2011 02:14 PM
FRKWOO
16
Nov 10, 2008 10:48 AM
kalm_traveler
Aug 31, 2008 02:10 PM
h22pwr
Jun 14, 2005 07:54 PM
LudEcrous
May 6, 2004 06:18 PM
