BBK SSI Manifold on turbo B18C1......slower???
Old Jan 5, 2005 | 07:43 AM
B18C1Crusader's Avatar
Default BBK SSI Manifold on turbo B18C1......slower???
Hello all, I am currently running a 95 gsr motor (stock internals) in my eg coupe, t3/to4e @ 8psi, emanage, custom garage kit. i put down 240hp @ wheels when i got it tuned several months ago and hit a 13.5 @ 104mph. I recently added a 3" mandrel downpipe and i could immediately tell the difference, it was much faster (had a crush bent 2.5" dp). I installed the new bbk manifold last night with a hondata intake gasket, and when I took it out for a test run it was SLOW! I could barely peel in first gear, when I usually loose traction as soon as I boost in 1st and 2nd gear.
Has anyone had a similiar problem with the jg manny? Did it throw my tune that far off that my car now feels like a 14 sec car?
I will throw my stock intake back on in a sec if I need to......
no cel, no leaks.....just slowness......any suggestions or ideas?
Old Jan 5, 2005 | 07:55 AM
m R g S r's Avatar
Default Re: BBK SSI Manifold on turbo B18C1......slower??? (B18C1Crusader)
you may need to re-tune it.
Old Jan 5, 2005 | 07:59 AM
VTC_CiViC's Avatar
I had the same exact feelings when I drove my car hard for the first time ..."what the hell is this?"
If the manifold is anything like the JG, it's a part of life. Back when my GSR was on the stock IM with the T04E, it felt much much quicker, even at 10psi. Now with the JG and SC61, the lag is pretty hefty and the IM doesn't aid in spool time either, it's a top end unit made specifically for LOTS of top end power, while sacraficing mid range velocity. Retune your car on the dyno and rev it out, notice how high your power curve trails with the new IM than it did with the stocker
Old Jan 5, 2005 | 08:09 AM
thanks mrgsr and vtc......I will definately get it re-tuned and maybe up the boost a bit......it was just soo much quicker with the stock im that it just seems....wrong.
I just called my tuning shop and they said that one thing I will need for proper tuning of that manny is a larger corresponding tb.......does that sound right?....on top of the 400 to tune my emanage i dont' want to drop another damn 350 on a damn tb!!
it just feels slow and I feel like I got bent over
Old Jan 5, 2005 | 09:09 AM
Luke J's Avatar
If you don't like the power-band of the bbk/ jg style, sell it and buy a skunk 2 or a Blox. It sounds like the longer runner manifolds might be more to your liking.
Old Jan 5, 2005 | 09:14 AM
VTC_CiViC's Avatar
E-manage? Oh dear.. sell the E-manage, take the money and buy/socket a P28 and have your tuners tune you via Uberdata. Your motor will thank you
And no, a larger TB isn't a neccesity.
Old Jan 5, 2005 | 09:33 AM
Default Re: BBK SSI Manifold on turbo B18C1......slower??? (VTC_resurected_CiViC)
Is the emanage hindering me that much? The shop in Austin seems to think highly of it......
Old Jan 6, 2005 | 04:15 PM
Luke J's Avatar
You may not feel that a larger TB is necessary for your setup, but if you want to make power with that manifold, the stock tb is a restriction. There is no point in running a short runner mani with a stock tb, the stock tb is choking that intake.
Old Jan 6, 2005 | 04:19 PM
TurboJesse
Guest
Posts: n/a
Default Re: BBK SSI Manifold on turbo B18C1......slower??? (Lucky925l)
FYI the BBK manifold is the JG manifold...all top end baby
Old Jan 6, 2005 | 04:29 PM
Luke J's Avatar
Default Re: BBK SSI Manifold on turbo B18C1......slower??? (Mpir3)
I have the JG mani, i didn't think I could even use a stock tb with that intake.
Old Jan 7, 2005 | 04:48 AM
Well, I am ordering the bbk 70mm tb to go with it, along with the hondata s200b. I found the tb for 289.00 and I may as well get the hondata instead of an e-01 like I was going to do, besides.....a friend wants to buy the emanage from me
I think with my new lsd, 3 puck exedy, and new hondata tuning I should be right back in the game! Thanks for the replies all
Old Jan 7, 2005 | 05:24 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_resurected_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">E-manage? Oh dear.. sell the E-manage, take the money and buy/socket a P28 and have your tuners tune you via Uberdata. Your motor will thank you
And no, a larger TB isn't a neccesity.</TD></TR></TABLE>
Stop it, stop it, stop it.... If you don't know about the system and you simply have your own recommendation, just say that.. But don't bash what you appear to have never utilized nor tried.
Old Jan 7, 2005 | 07:45 AM
Luke J's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1Crusader &raquo;</TD></TR><TR><TD CLASS="quote">Well, I am ordering the bbk 70mm tb to go with it, along with the hondata s200b. I found the tb for 289.00 and I may as well get the hondata instead of an e-01 like I was going to do, besides.....a friend wants to buy the emanage from me
I think with my new lsd, 3 puck exedy, and new hondata tuning I should be right back in the game! Thanks for the replies all</TD></TR></TABLE>
I think a 65mm tb will be big enough for you..
philly10psi
Jun 8, 2011 08:05 AM
jimmy051702
May 12, 2011 04:27 PM
EtchaSketch
Mar 10, 2005 01:13 AM
silverstreak20
12
Mar 21, 2004 02:18 PM
