EG Civic Wont Start?!?!
Old Jan 5, 2005 | 06:41 AM
Evil DOHC's Avatar
Default EG Civic Wont Start?!?!
Here is the run down. 1992 Honda Civic Dx. Fuel Pump is not priming. Fuel pump is good, checked it with voltage. Just put a brand new main relay in the vehicle as well. Car turns over and everything is fine but the fuel pump wont prime for some reason. Checked all fueses and grounds already as well. What could be the problem?
Any input is highly appreciated
Old Jan 5, 2005 | 06:59 AM
bbarbulo's Avatar
could there be a fuel cutoff switch you dont' know about (if you bought the car second hand?) I'd run a wire from the main relay to the pump and try again... if the car starts, just replace the wire man...
Old Jan 5, 2005 | 07:02 AM
civic99b16a's Avatar
Default Re: (bbarbulo)
break out the multimeter and see if your getting power at the realy whith koeo there should be a 12v signal sent to the relay the pump is only suppose to turn on for a quick second before its started try clicking to key on and off a few times to make fuel pressure rise i had that problem once also make sure you have an adequate amount of gas
Old Jan 5, 2005 | 07:06 AM
Evil DOHC's Avatar
Default Re: EG Civic Wont Start?!?! (Evil DOHC)
Checked the power, we are getting power at the relay and the car has a half tank of gask. I am about to hardwire the f***in thing. Any other suggestions?
Old Jan 5, 2005 | 07:08 AM
what about power coming out of the relay apply 12 volts to the sihnal wire you haear clicking right?? after the clicking see if you see a 12 volt signal leaving the relay
Old Jan 5, 2005 | 07:17 AM
Evil DOHC's Avatar
Default Re: EG Civic Wont Start?!?! (civic99b16a)
No power leaving the relay. Tried 4 diff relays already. I hear a click when you first turn the ignition on, I dont hear the second click or the fuel pump priming. What else could it be?
Old Jan 5, 2005 | 07:44 AM
Evil DOHC's Avatar
Wierd thing just happened, tried to jump the computer to run the codes and the car decided to start. Shut it off and tried it about 10 times, kept starting every time. Its like the car is cursed lol
Old Jan 5, 2005 | 08:23 AM
Teggys1ClnDA's Avatar
that's weird. maybe it was just something small. i dunno. at least it's working now though.
Old Jan 5, 2005 | 01:11 PM
Evil DOHC's Avatar
Hopefully it will continue to keep starting.
EVIL
Old Jan 7, 2005 | 04:50 AM
Evil DOHC's Avatar
UPDATE:
After checking every single wire in the harness, replacing the main relay, testing every single fuse, replacing the fuel pump etc. The conclusion was a faulty ecu. I never had an ecu go dead on a honda, but know atleast I know that it "could" happen. I am aware that a lot of DSM ecu's go dead, but never seen a honda/acura ecu go sour.
BTW, I will try to do a write up on this in the future, since I have seen a lot of posts about similar problems that people are having with their vehicles.
EVIL
Old Feb 9, 2005 | 06:48 AM
stardog's Avatar
Evil DOHC,
If you get this post, email me at psmwrx@gmail.com asap
Thanks,
John L
Je$$eDB8
Sep 2, 2008 12:52 PM
thegooddoctorceretti
Audio / Security / Video
Sep 18, 2007 06:27 PM
ALL MOTOR DA
35
Aug 18, 2006 09:44 PM
0817crx
Sep 18, 2005 08:00 AM
Chuckyb
Dec 11, 2004 05:45 AM
