Hytech Header Install?
Does anyone have any pic's of their Hytech install? Just wondering what you guy's have done. Did you cut your B-pipe or did you just make a small test pipe?
http://members.tripod.com/mintydip/
Edit: sorry, not Hytech specific...
[Modified by Flux, 4:08 PM 1/8/2002]
Here is what I did...unfortunately with the loss of photopoint I can't give you the pics.
1.) Modified brace that secures transmission to block, problem only presents itself on the Type-R as the Type-R is the only car that has a burly brace, the gsr brace is fairly small and does not have a clearance problem.
2.) I used a Carsound 54006 catalytic converter originally produced to connect the stock b-pipe to a JDM header.
3.) I had 8.5" removed from the aftermarket b-pipe that I purchased from Comptech to accommodate the increased length on the HyTech header.
Any other questions?
Austin
Austin
is that header brace necessary? I got a 5zigen header, but the brace is diff so I left it off for now.
yoshi - whose kinda worried that he's not using the header brace
As it happens the piece that you have to modify to fit the HyTech header is also the piece that you have to modify to install the Moroso oil pan, just some fyi that I have.
Austin
You dont need the header brace.
You dont even really need the intake manifold support.
The block brace is what Austin is referring to.
iperez
Nov 21, 2003 12:21 PM
your exhaust doesn't sit all that far off the ground. Mine has a lot more ground clearance than that.
