any benefit to swapping a crx si head to my dx? i figured there would be some
Old Jan 4, 2005 | 07:45 PM
homeskillet's Avatar
Default any benefit to swapping a crx si head to my dx? i figured there would be some
hey theres a rex si in the junkyard with 89k miles on it. i took off the valve cover and everything inside looks premium. i would like to put this head onto my civic because this si head will save me mad cash instead of buying a cam for my civic. any thoughts on this? what gasket should i use? metal d16y8? or is that a bad idea?
Old Jan 4, 2005 | 08:24 PM
ABK's Avatar
ABK
Default Re: any benefit to swapping a crx si head to my dx? i figured there would be some (homeskillet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homeskillet &raquo;</TD></TR><TR><TD CLASS="quote">hey theres a rex si in the junkyard with 89k miles on it. i took off the valve cover and everything inside looks premium. i would like to put this head onto my civic because this si head will save me mad cash instead of buying a cam for my civic. any thoughts on this? what gasket should i use? metal d16y8? or is that a bad idea?</TD></TR></TABLE>
I thought that dx head flows pretty good stock almost as good as z6. I might be wrong though. It doesn't have vtec but flow okay I guess. I think there was someone that ported the **** out of it and put a cam in there and made some good numbers.
Old Jan 5, 2005 | 05:34 PM
im thinking about a d16a6 head from a crx/civic si. i can get it for super cheap... so i thik it may be worth a try
Old Jan 5, 2005 | 06:34 PM
BauleyCivic's Avatar
Risky Business
Default Re: (homeskillet)
88-91 CRX Si and 92-95 Civic DX have the same head cast
Old Jan 5, 2005 | 07:22 PM
lohatch's Avatar
Default Re: (BauleyCivic)
yah they are the same damn head. the cam is a touch different but you arent going to get hardly any gains from it. the A6 makes 2 more HP than your DX from the factory.
Old Jan 5, 2005 | 07:47 PM
ABK's Avatar
ABK
Default Re: (lohatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch &raquo;</TD></TR><TR><TD CLASS="quote">yah they are the same damn head. the cam is a touch different but you arent going to get hardly any gains from it. the A6 makes 2 more HP than your DX from the factory.</TD></TR></TABLE>
if you want gains without swapping over to vtec head, buy a reground cam, maybe port and mil the head.
Old Jan 5, 2005 | 07:55 PM
damn.. i thought i may be onto sumthing worthwhile. i guess that is like my 5th cost saving idea that has been scratched. damn hondas are expensive as ****.
Old Jan 6, 2005 | 05:51 PM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homeskillet &raquo;</TD></TR><TR><TD CLASS="quote">damn.. i thought i may be onto sumthing worthwhile. i guess that is like my 5th cost saving idea that has been scratched. damn hondas are expensive as ****.</TD></TR></TABLE>
Or maybe you're just cheap
Old Jan 6, 2005 | 06:08 PM
sleeping GIANT's Avatar
Default Re: (88 rex)
there not that expensive , if you dont make dumb decisions , why not do a z6 head, p-28 ecu, y8 head gasket.......? mini/turd yo!
-then you might be able to pull some stage 3 burn-outs like ME !
Gumbey75
Mar 11, 2006 12:47 PM
98rsteg
20
May 17, 2004 01:28 PM
Nextelbuddy
Mar 8, 2004 10:05 AM
Broken Gearbox
Apr 5, 2003 10:48 PM
TeamUndefinedHFCRX
Jan 7, 2003 10:08 AM
