ecu plugs
Old Jan 4, 2005 | 07:31 PM
black2001ITR's Avatar
Default ecu plugs
I have a motec and i want to make the install of it as neat as possible.
I need to make up a wiring loom that runs from the factory wiring harness to the motec plug.
My problem is, i dont know what the plugs are called that i could use to plug into the factory loom, nor where to find them.
If anyone has some links or info on it, it would be greatly apprieciated
Thanks guys
Old Jan 4, 2005 | 07:47 PM
b19coupe's Avatar
Default Re: ecu plugs (black2001ITR)
You could buy an OBD2 to OBD1 adapter harness if you are just looking for the connectors. Don't know of anywhere to purchase just the connectors.
Old Jan 4, 2005 | 07:48 PM
ok thanks, know of any places where you can get the harness's???
Old Jan 4, 2005 | 08:06 PM
b19coupe's Avatar
Default Re: (black2001ITR)
http://www.jhpusa.com/catalog/...d9039
https://honda-tech.com/zerothread?id=1045659
Look around. Lots of used ones for sale, and most major Import Performance stores carry adapter harnesses.
Old Jan 4, 2005 | 11:10 PM
Blown90hatcH's Avatar
Default Re: (b19coupe)
I will sell you what ever you need man. Hit me up.
Jason
http://www.JKobdconversionharness.com
https://honda-tech.com/zerothread?id=997093
710dabber
Feb 27, 2015 07:13 PM
Sonik_fury
Sep 11, 2005 01:39 PM
Vsm Hatch
Welding / Fabrication
Feb 5, 2005 06:41 PM
monicle
Dec 29, 2003 08:52 AM
GripFactoR
Nov 21, 2003 02:36 PM
