Suspension & Brakes Theory, alignment, spring rates....
I want my car to ride better, right now it's a rattle box.(Bushings)
Old Jan 4, 2005 | 01:19 PM
leadfoot78's Avatar
Default I want my car to ride better, right now it's a rattle box.(Bushings)
A few weeks ago I was under my car and I looked at all my suspension bushings, they are all shot, I mean most of the are cracked all the way through. Which bushings are the most important to replace? I know I don't want a full polyurethane kit cuz that will make it ride way to harsh. Which bushings should I replace? OEM or is there some thing better, some thing that will handle better and have an "ok" ride comfort. Finally, where do I buy it for the best price?
Old Jan 4, 2005 | 01:20 PM
Teknic73's Avatar
Default Re: I want my car to ride better, right now it's a rattle box.(Bushings) (leadfoot78)
it sounds like oem would be best for you.
Old Jan 4, 2005 | 01:24 PM
Tyson's Avatar
Default Re: I want my car to ride better, right now it's a rattle box.(Bushings) (Viorent Grip! 73)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Viorent Grip! 73 &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like oem would be best for you.</TD></TR></TABLE>
if you dont want poly bushings, then it sounds like you just want OEM. but OEM aint so cheap either. mugen is the only other option, but at an even higher premium.
front end looseness could be balljoints and steering rack bushings as well. you really either figure which ones are loose and replace one by one, or just replace everything, likely theyre all in some degree of needing replacement if the car is over 10 years old.
Old Jan 4, 2005 | 02:28 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
OEM bushings are expensive, and harder to install, but they will give you the ride you're looking for.
Old Jan 4, 2005 | 05:56 PM
teamsol's Avatar
if you have the money, i would do mugen. They are the stock bushing but harden.(yah i know he said he wanted a better ride).
Modified by teamsol at 5:21 PM 1/5/2005
Old Jan 4, 2005 | 11:05 PM
leadfoot78's Avatar
Default Re: I want my car to ride better, right now it's a rattle box.(Bushings) (teamsol)
Hey Damian you don't know this but we've meet, I was a Trines house when he was putting in his H22. You came over to check out my white hatch, it was on the jack stands then, it's alive and very well now though. So where can I find oem or Mugen bushings for the best price? The other day I was doing a 3rd gear pull and when vtec hit I lost traction, my suspension is not up to par with the motor at all.
Old Jan 5, 2005 | 04:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamsol &raquo;</TD></TR><TR><TD CLASS="quote">If you need to replace your rear trailing arm bushings, you cannot buy oem bushings. You would have to buy the complete rear trailing arm assembly.</TD></TR></TABLE>
Actually Honda does sell the bushing seperately. You just need to have the part #. Unless the dealer threw out the arm and charged me 1/5 the price, I have a set on my car.
Old Jan 5, 2005 | 04:37 AM
.RJ's Avatar
.RJ
Default Re: I want my car to ride better, right now it's a rattle box.(Bushings) (MugenDude)
http://www.acuraparts247.com
Old Jan 5, 2005 | 08:20 AM
teamsol's Avatar
hey thanks for the info Mugendude, i was not aware that you could just purchase the oem Bushings. Would you happen to have the part number? i actually need to replace mine.
LeadFoot78: Martin yah i remember. Trine told me you took him out for a ride, he said even at 5000rpm your car felt fast as ****. Let me know what kind of numbers you put down. And i believe the best place to buy the mugen bushings are from http://www.kingmotorsports.com, or oem from sunnyside acura like .RJ sugested.
Old Jan 5, 2005 | 08:22 AM
teamsol's Avatar
previous posted editied
Old Jan 5, 2005 | 09:00 AM
teamsol's Avatar
FOLLOW UP: I promise this is the last time ill post in this thread.
I called Acura of Tempe and Acura of North Scottsdale (these are local acura dealers for the guys that do not live in AZ) and the both said you would have to buy the complete trailing arm.
Then i called Honda cars of Mesa and through Honda you can buy the same bushing which is the same as the integra bushing. The part number is 409829 and they cost 58.74 per side plus tax. So they would be about the same price as the mugen harden bushings. Hope this helps some people out.
Old Jan 5, 2005 | 09:20 AM
acy76's Avatar
There was a huge thread on the rear trailing arm bushing "controversy" a while back on G2IC.
Alternatively, you could IM Wes V on here -- he was involved in the aforementioned thread. I believe he has some info on his personal web page as well (no links, I'm at work...)
Old Jan 5, 2005 | 09:53 AM
AlxSiR7's Avatar
all 4 banger hondas are rattle boxes man.. get used to it
Old Jan 5, 2005 | 09:57 AM
.RJ's Avatar
.RJ
Default Re: I want my car to ride better, right now it's a rattle box.(Bushings) (AlxSiR7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlxSiR7 &raquo;</TD></TR><TR><TD CLASS="quote">all 4 banger hondas are rattle boxes man.. get used to it</TD></TR></TABLE>
My ITR doesnt rattle
Old Jan 5, 2005 | 10:01 AM
Big Phat R's Avatar
you drive a 93 CX? what do you expect!?
It might be less hassle to buy a new chassis and put the motor you built in that one.
Old Jan 5, 2005 | 11:17 AM
Mike_C's Avatar
Default Re: I want my car to ride better, right now it's a rattle box.(Bushings) (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
My ITR doesnt rattle </TD></TR></TABLE>
that's an acura.
Old Jan 5, 2005 | 11:20 AM
.RJ's Avatar
.RJ
Default Re: I want my car to ride better, right now it's a rattle box.(Bushings) (Mike C)
I forgot... "acuras are better than hondas" - mikes dad
Old Jan 5, 2005 | 05:34 PM
dynamat and suspension work does wonders.
ef8-dc2619
Suspension & Brakes
21
Feb 2, 2014 08:29 AM
vinuneuro
Suspension & Brakes
Jun 19, 2006 02:02 PM
Caveman74
13
Nov 27, 2005 04:36 PM
clarkekent13
Suspension & Brakes
Jul 25, 2005 07:57 PM
Eyewitness
18
Aug 27, 2003 07:15 PM
