Best Engine Break in Oil
Old Jan 8, 2002 | 09:42 AM
Crazydave's Avatar
Default Best Engine Break in Oil
What oil and weight do you recommend for breaking in a new motor?
Old Jan 8, 2002 | 09:44 AM
WAFFLES's Avatar
Default Re: Best Engine Break in Oil (Crazydave)
Mobil1 5W30/10W
Old Jan 8, 2002 | 09:45 AM
rioninja's Avatar
non-synthetic of course.
Just stick with the stock weight, but change it often.
Some mobile-0 or plain castrol will do fine.
Old Jan 8, 2002 | 09:50 AM
Crazydave's Avatar
Default Re: Best Engine Break in Oil (RioNinja)
why non-synthetic?
Old Jan 8, 2002 | 09:51 AM
WAFFLES's Avatar
The rings will not set properly.
Old Jan 8, 2002 | 09:55 AM
Crazydave's Avatar
Default Re: Best Engine Break in Oil (WAFFLES)
I'm just curious as to why synthetic causes rings to not set properly
... does anyone know..
Old Jan 8, 2002 | 10:27 AM
GM2000ITR's Avatar
New User
The theory is that generally, synthetic oils contain detergents and "clings" to moving parts very well (hence it's great reputation for racing applications), however, during a break-in, your main objective is to have your rings seat properly. By using a "lower grade" oil (usually 30w, organic, non-detergent), the cylinder walls are not cleaned and lubed as much and allow for the rings to "take the shape" of the cylinders (seat) properly. The use of the oil is alos the reason for low and fluctuating rpm driving during break-in. Hope this helps!!
Old Jan 8, 2002 | 10:36 AM
Crazydave's Avatar
Default Re: Best Engine Break in Oil (GM2000ITR)
hell yeah.... thanks for the info...
so you recommend 30 weight(non multiweight) organic ?
Old Jan 8, 2002 | 10:40 AM
Mike K's Avatar
I use 2 quarts of Honda 0w20 and 3 quarts of Honda 5w30 on break-in.
If the motor has forged pistons, I'll sub the 0w20 for 2 more qts of 5w30.
Honda oil = Mobil oil w/ special "additives" for Hondas only
Not sure if it's a ploy or not, but since I get it cheap as **** at work, I use it.
Old Jan 8, 2002 | 10:56 AM
Crazydave's Avatar
Default Re: Best Engine Break in Oil (Mike K)
Cool...
Nice avitar! Have you ever met him....he's pretty cool
Old Jan 8, 2002 | 11:01 AM
GM2000ITR's Avatar
New User
Yeah, straight 30w non-detergent smells like *** but works great. That's all the knowledge about oil I can offer. Mike K is da man! He know his **** (re: oil -n- stuff), I'm sure he can answer just about any ?? you can throw at him!
Old Jan 8, 2002 | 11:07 AM
Crazydave's Avatar
hmm...5 quarts.. in a D-Series.. will it hold it?
Old Jan 8, 2002 | 01:32 PM
976's Avatar
976
New User
Never put more oil than designed for. Too much pressure.
10w30 summer
5w30 winter
Break in conventional oil - Why not use honda fluid?!
Old Jan 8, 2002 | 05:19 PM
Mike K's Avatar
Default Re: Best Engine Break in Oil (B21A)
Not sure. Check in the Helms.
Not oil pressure. Too much oil causes parasitic drag on the crank and under high rpm, can cause oil to foam and/or bubble.
But 5 quarts on an engine rebuild is standard for a B-series.
4.2 quarts @ oil change
5.0 quarts @ fresh start-up
Old Jan 8, 2002 | 05:58 PM
sgT's Avatar
sgT
Mobil1 5W30/10W
Mobil1 is synthetic.
Old Jan 8, 2002 | 06:05 PM
HENRY's Avatar
New User
Use non-synthetic 5W-30 or 10W-30. You need a little bit of the friction during break in and it is like the final machining of the engine. Hope that made sense. Lastly, I think D-series motors only require about 3.5 quarts. 4 is OK but don't put more then that.
Old Jan 8, 2002 | 07:16 PM
Crazydave's Avatar
Default Re: Best Engine Break in Oil (HENRY)
yeah.. I think mine is 3.8 .. I'd have to double check I know that 5 was too many
[Modified by Crazydave, 4:17 AM 1/9/2002]
Old Jan 9, 2002 | 04:53 AM
Mista Bone's Avatar
D Tranny Guru
20w or 30w non detergent
FireInTheHead
Nov 4, 2014 04:15 PM
joss731
Sep 15, 2010 08:50 AM
aeolus
62
Mar 13, 2009 08:24 PM
2wheelhunter
Nov 6, 2008 07:19 AM
92teginsc
Aug 4, 2008 11:08 AM
