270degree thrust bearing vs a 360 degree thrust beering
the difference is really about longevity of the turbo. Both will last about 200,000 miles or so w/o much issue, but the 360 degree bearing can take a bit more heat, a bit more punishment, and keep things running at an optimal level a bit longer
the 360* thrust bearing provides greater oiling and shaft protection under higher thrust loads. (higher boost pressures(above 16psi on a daily basis, improperly sized turbine housings, mismatched wheels, etc..)
about 90% of our customers using T3/TO4E turbos use the factory 270* thrust with zero problems.
however, when moving up to the larger compressors mated to the smaller T3 turbine sections, it is recommended to run the 360* thrust to prolong the life of the turbocharger.
we do a large amount of rebuilds on all different types of turbochargers and hardly will we see a thrust loss as cause of failure. the main cause of failure is improper oiling, or oil contamination.
hope this helps
hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markvqwerty »</TD></TR><TR><TD CLASS="quote">btw mochasi: k1 fan or where did you get the name from?</TD></TR></TABLE>
my doggy is named mocha
see the icon .. i luv him haha
.. whats k1 ???
.. whats k1 ???
abidi?? he is a cheater! cant stand him!
i like ignashovs style!
and of course peter aerts,ernesto hoost and remy!
not only because im from holland to!
i like pride also but its neve3r on the television
boosted_dc2
Sep 5, 2003 02:01 PM
