Car slow / not starting in cold weather?
Old Jan 4, 2005 | 09:35 AM
dumbchild's Avatar
Default Car slow / not starting in cold weather?
Temperatures have recently dipped down to about 0 or -1 at night.
Since then my car has been having trouble starting up in the mornings, it takes a couple turns of the key before the engine will turn over (once it turns over it starts right up).
Is this indicative of a low battery?
I've had the car for two years and not changed the battery in that time - so I don't know how old it is.
(93 si hatch w/ D16 - not that it matters in this case I don't think)
Thanks in Advance.
Old Jan 4, 2005 | 09:46 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Car slow / not starting in cold weather? (dumbchild)
Dude, its 0. 0!! Im impressed the car even starts at that temp lol. The battery will tend to take a little more coaxing. Also your oil is really REALLY thick at that temp. Once it starts, let your car warm up. You'll be okay.
Old Jan 4, 2005 | 10:12 AM
snatch's Avatar
Default Re: Car slow / not starting in cold weather? (JDM_Ej)
I concur, it's just because it's so damn cold. Just let it warm up for a few minutes or at least drive it easy until it warms up.
Old Jan 4, 2005 | 10:52 AM
dumbchild's Avatar
Sorry guys - should of put 0 degrees celcius...
Not that cold actually!
Thats why I'm wondering if it's the battery...
(I'm in Canada)
Old Jan 4, 2005 | 10:59 AM
Filthy Focker!'s Avatar
At 0 degrees celcius, you should not have any problems starting your car. Batteries sold in Canada are made for cold weather.
Describe your symptoms better.
How old is your battery?
Does it have one of those green indicators on top? How does it look?
Does the starter turn really slowly?
fs
Old Jan 4, 2005 | 11:02 AM
AutoXer's Avatar
Default Re: Car slow / not starting in cold weather? (filthy_shovel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">At 0 degrees celcius, you should not have any problems starting your car. Batteries sold in Canada are made for cold weather.
Around 30F, I sometimes get slow cranking. Around 15F, I always crank slow. But it always starts. I know other hondas that are the same, so I figured it was normal.
Old Jan 4, 2005 | 12:08 PM
dumbchild's Avatar
The battery is more than 2 yrs old since I have had the car for 2 yrs so I don't know how old the battery is beyond that point.
In the morning I get in the car turn the key halfway. The fuel sytem primes etc. Turn it the rest of the way and absolutely nothing happens. Leave it for a second, try again and nothing. Try a third time and after a long pause of nothing, the engine will start up normally.
Sometimes it starts first try or second or fourth... very random...
Once I have driven the car and its warmed up, there is no problem starting it at all. Only when it's left overnight does the problem occur.
There is no indicator on the battery.
Old Jan 4, 2005 | 05:04 PM
dumbchild's Avatar
If anyone cares:
Just got the battery tested - it was almost dead.
So yes, the cold does affect a weak battery.
Got a new battery now...
josephshark
Mar 29, 2009 07:44 PM
pdiggitydogg
Jan 11, 2007 07:36 PM
dman81
May 16, 2005 08:18 PM
eymnewdc4
Jan 23, 2005 12:51 PM
B18C-RnVA
Nov 7, 2002 04:44 PM
