Where is the thermostat located on a '96 Accord?
Old Jan 3, 2005 | 09:14 PM
jaygtyj's Avatar
Default Where is the thermostat located on a '96 Accord?
Please be very detailed in your description. Also, how hard is it to change?
Thanks.
Old Jan 3, 2005 | 09:19 PM
Carolina Fried Rice's Avatar
Default Re: Where is the thermostat located on a '96 Accord? (jaygtyj)
look at the radiator hose, follow it until it gets to the block. Thats the thermostat housing. Not hard to replace either.
Old Jan 4, 2005 | 07:47 AM
Filthy Focker!'s Avatar
Default Re: Where is the thermostat located on a '96 Accord? (TSAF22B1)
Top hose of the rad going to the block.
Remove the bolts, pop out the thermostat. Some coolant of course will leak out but not to worry. Scrape off old gasket completly.
Install new gasket. You can use a couple of dabs of grease to hold it in place if it moves on you. Then install thermostat RIGHT SIDE UP. Reinstall bolts. Turn car on look for leaks and top up fluid.
fs
TheeInitiative
Mar 24, 2014 02:50 PM
fomococo
Jul 17, 2012 05:39 PM
azandford
May 18, 2010 07:46 AM
97hosein
Jul 27, 2006 06:00 AM
jdm555
13
Mar 12, 2004 08:24 PM
