96 EX Keyless entry (already searched)
Old Jan 3, 2005 | 08:17 PM
EeeJayEight's Avatar
Default 96 EX Keyless entry (already searched)
do ALL 96 ex's come stock with keyless entry?
I wanna know becuase i wanted to buy a remote from honda but i dont wanna waste money
if i dont have it...anyway to find out if its not a stock option?
Old Jan 3, 2005 | 08:22 PM
green-'s Avatar
Default Re: 96 EX Keyless entry (wHiTe91hAtChBaCk)
My 2000 EX didnt come with keyless entry. It was a dealer option im almost positive.
Old Jan 3, 2005 | 08:33 PM
_Cyclone_'s Avatar
You need to have the stock deck in the car for the keyless to work. If you have it, pull it out and look on the back at the plugs. You should see the radio harness, antenna and if it has or had keyless entry, there should be a green security plug too.
Old Jan 3, 2005 | 08:56 PM
civictildeath's Avatar
Default Re: 96 EX Keyless entry (CycloneBlue_1.6EL)
the honda dealer run your vin # to know for certain
Old Jan 3, 2005 | 10:10 PM
CrOmEdOmEcHaMbEr's Avatar
Default Re: 96 EX Keyless entry (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL &raquo;</TD></TR><TR><TD CLASS="quote">You need to have the stock deck in the car for the keyless to work. If you have it, pull it out and look on the back at the plugs. You should see the radio harness, antenna and if it has or had keyless entry, there should be a green security plug too.</TD></TR></TABLE>
Cyclone is correct, the receiver is built into your factory radio...
but...
only in the 96-98 Civic HX and Civic LX...
Old Jan 3, 2005 | 10:16 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHiTe91hAtChBaCk &raquo;</TD></TR><TR><TD CLASS="quote">do ALL 96 ex's come stock with keyless entry?
if i dont have it...anyway to find out if its not a stock option?</TD></TR></TABLE>
you're better off buying an aftermarket alarm. for the cost of 2 tranmitters from honda, you can have a full featured alarm. btw, the honda keyless is not an alarm.
Old Jan 3, 2005 | 10:20 PM
Default Re: 96 EX Keyless entry (CrOmEdOmEcHaMbEr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrOmEdOmEcHaMbEr &raquo;</TD></TR><TR><TD CLASS="quote">Cyclone is correct, the receiver is built into your factory radio...
but...only in the 96-98 Civic HX and Civic LX...</TD></TR></TABLE>
then where is the reciver located in the 96-98 ex?? and why did i have to keep my stock radio when going aftermaket??
you can buy remotes on ebay
Old Jan 3, 2005 | 10:25 PM
_Cyclone_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrOmEdOmEcHaMbEr &raquo;</TD></TR><TR><TD CLASS="quote">only in the 96-98 Civic HX and Civic LX...</TD></TR></TABLE>
I always thought it was for all 96-98 models... however, my 97 1.6EL has the brain for the keyless entry/security system under the driver's seat. My EL is similar in many respects to the EX in the US.
Old Jan 3, 2005 | 10:49 PM
untitledsn41's Avatar
I always thought it was for all 96-98 models... however, my 97 1.6EL has the brain for the keyless entry/security system under the driver's seat. My EL is similar in many respects to the EX in the US.</TD></TR></TABLE>
you are right, i know of 2 people who have 96-98 EX coupes with the remote keyless entry. both of them retained their stock decks behind the dashboards so they could keep the remote keyless entry. most of the audio places around here will do that if you buy a new deck.
but i would just take it to a Honda stealership and have them run your VIN and check it out for you
Old Jan 3, 2005 | 11:07 PM
_Cyclone_'s Avatar
Default Re: 96 EX Keyless entry (untitledsn41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitledsn41 &raquo;</TD></TR><TR><TD CLASS="quote">but i would just take it to a Honda stealership and have them run your VIN and check it out for you</TD></TR></TABLE>
That would definitly be easier than what I suggested before.
Old Jan 4, 2005 | 07:27 AM
thanks guys...would they run the VIN for free...?
Also the lady i bought it from had some alarm in there buy i dont know why nothing worked on it..
i pulled the brain out and just left the wires cuz i didnt know where they went...do u thinik it would be a lot to have someone troubleshoot my alarm?
Old Jan 4, 2005 | 09:40 PM
im sure if you go in there and tell em your situation they will check it out for free.
ej8ster96
May 9, 2012 07:13 AM
shortyscivic
Audio / Security / Video
Feb 24, 2006 09:41 PM
Screaminz28
Aug 3, 2005 02:21 PM
supadupamikey
Aug 15, 2003 12:28 PM
chankyeyes
Apr 25, 2003 09:33 PM
